Old 04-16-2004, 05:09 PM
Igovert500's Avatar
blue + red light magnet
alarm battery?
Quick question for you guys who know alot about alarms..the battery is dying on my Python alarm remote. I found a battery for 4 bucks, can I just replace it, or does it need reprogramming after replacing the battery?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 04-16-2004, 06:01 PM
sLADe781 sLADe781 is offline
Re: alarm battery?
You shouldn't need to reprogram anything. I replaced the battery on my alarm's remote and everything was okay. So unless if your alarm is some special high-tech one, it'll probably be fine.
Old 04-16-2004, 11:51 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
Re: alarm battery?
my pops alarm on his vette when you replace the battery, you have to put the key in the ignition, hold lock and unlock at the same time for 10 sec until you hear a honk and then its programmed.
Old 04-17-2004, 06:01 AM
BB1970's Avatar
BB1970 BB1970 is offline
Re: alarm battery?
yes you should be ok with that make just make sure you change it within 30 secs as some remotes have a memory in them.
1993 Mitsubishi GTO Twin Turbo (RHD) NOW SOLD!!!
9b turbos with manual boost valve mod set @14psi
turbo xs type h-rfl blow off valve
blitz dome filter
sachs clutch
completely de-catted
fuel pump voltage rewire mod
ebc redstuff front brake pads
greddy fully automatic turbo timer
now drives a sensible family sedan. A 340hp 1997 mitsubishi evolution IV
Old 04-17-2004, 09:28 PM
Igovert500's Avatar
Re: alarm battery?
sounds good...thanx
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 04-18-2004, 09:47 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: alarm battery?
I sell Python alarms. You will be OK to change out the battery. Might want to clean out the contacts when you do. Also, go to Walmart and buy the battery for $1.25 for a pack of 2!
