View Poll Results: Do you paint your parts on or off the tree
Yes 10 32.26%
No 21 67.74%
Voters: 31. You may not vote on this poll
Old 04-16-2004, 05:08 PM
supermod04's Avatar
supermod04 supermod04 is offline
Banned
Send a message via AIM to supermod04 Send a message via MSN to supermod04
Do you leave the parts on the tree when you paint?
do you guys leave all your parts on the trees and paint and then take them off and touch up or cut each one out and paint it?
Old 04-16-2004, 05:11 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Both. Depends on the parts.
-Mike
Old 04-16-2004, 05:41 PM
Vric's Avatar
Vric Vric is offline
Re: Do you leave the parts on the tree when you paint?
exactly yes.. except for body parts
Old 04-16-2004, 06:05 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
+1 for both, though often the parts are attached to the tree in a bad place, so I've been known to cut it off and use a tiny drop of superglue to reattach ther part to the tree using a hidden surface. This is most common for steering wheels.
Old 04-16-2004, 06:24 PM
935k3's Avatar
935k3 935k3 is offline
I always remove and cleanup all parts. Models examined closely will show the difference.
Old 04-16-2004, 07:01 PM
supermod04's Avatar
Banned
i do both myself. i will leave some on and then pull them off sand them and touch up.
Old 04-16-2004, 07:20 PM
Sigmaman's Avatar
Sigmaman Sigmaman is offline
AF Premium User
Send a message via MSN to Sigmaman
Same as him.
www.sigmamansmodels.com
Old 04-16-2004, 08:32 PM
RallyRaider's Avatar
Zomby Woof
In 99.99% of cases I remove them from the sprue/tree before painting. You need to in order to trim the join and scrape/sand down all the mold lines. Or am I the only guy silly enough to do that to every single piece of the kit?
Old 04-16-2004, 08:36 PM
Zomby Woof
Just went to vote and found the possible responses don't fit the poll question Would you like it (super) modified 04?
Old 04-16-2004, 10:21 PM
StephenDeli's Avatar
StephenDeli StephenDeli is offline
Send a message via AIM to StephenDeli
When I spray things I usually take them off the sprue. When handbrushing I always leave on the sprue and touch up.
Current Projects- Ferrari F189 ON HOLD
Ferrari 360 Spider
Future Projects-04' Corvette Z06, Enzo, F1-2000
Old 04-16-2004, 11:06 PM
supaman89's Avatar
supaman89 supaman89 is offline
Send a message via AIM to supaman89 Send a message via Yahoo to supaman89
In 99.99% of cases I remove them from the sprue/tree before painting. You need to in order to trim the join and scrape/sand down all the mold lines. Or am I the only guy silly enough to do that to every single piece of the kit? <<<<<< i do this 2 im anal bout it lol
Old 04-16-2004, 11:58 PM
supermod04's Avatar
Banned
i will leave them on then paint, then break them off and touch them up it is easy
Old 04-17-2004, 01:43 AM
Actually after some thought, I realize that I remove most, if not all parts from the tree before painting, for the same reason RallyRaider pointed out. I will, like I said before, glue them back to the sprue with a tiny bit of glue, however, using the surfaces designated for mounting. It would be so nice if the model companies would make the attachement points the mounting surfaces from the beginning, so they could save me this step. I really hate touching up, because brush painting never ends up looking like spray paint. Not ever. For me.
Old 04-17-2004, 03:13 AM
sjelic's Avatar
sjelic sjelic is offline
I usually take them off but if there is some part that will be hard to reach after assembly (like back side of brake disc) I paint only that back side and then attach it and paint it affter assembly, only thing that I spray paint when on tree are exhaust pipes and after attaching them I detail paint them when they are fixed on model
Rgds,
Sasa Jelic
SCALEMAKERS
Old 04-17-2004, 03:24 AM
vwman's Avatar
vwman vwman is offline
Same here
-Mika
