Old 04-16-2004, 03:21 PM
dingpoo dingpoo is offline
Send a message via MSN to dingpoo
reverse lights dont work
i have fog lights for reverse lights as well as my regular tail light reverse lights and neither seem to be working any more. i have checked the fuses and i quickly cheked the wiring. both looked fine, any suggestions?
Old 04-17-2004, 01:23 PM
pind pind is offline
Re: reverse lights dont work
check the reverse light switch, chances are its hooped. if you are using auxilliary backup lights, you should put them on a seperate relay, triggered by the stock b/u lights. this way the switch does not have to handle so much current, and will not burn out.
Old 04-18-2004, 06:53 AM
Jeremy-WI Jeremy-WI is offline
It could be corrosion on the T connection near the rear bumper, a lot of the time all it needs is some dielectric grease
Old 04-19-2004, 05:47 PM
daemonhat daemonhat is offline
you might also want to try checking the switch in the column, if it has one, i have an 88 C/K 2500 and you have to wiggle the gear shift a bit for the reverse lights to come on
Old 04-19-2004, 11:08 PM
gjosuem's Avatar
gjosuem gjosuem is offline
If you have a standard, I believe that you may have sensor/switch on the tranny and it might be bad or need adjustment
Old 04-20-2004, 12:44 PM
markqc markqc is offline
How would you go about checking or adjusting the sensor/switch on a manual transmission? Where is it located?
Mark
Old 06-20-2004, 02:41 PM
gjosuem's Avatar
I believe the sensor is located on the top of your transmission, look for some wires. This sensor is basically a plunger switch that has a couple o-rings and nylon washers, it may be stuck and the circuit is not being closed because it does not have its complete travel path. Sorry for the late reply. If you replace it, check to make sure it moves freely before putting it it.
Old 07-02-2004, 10:39 AM
pickering_c pickering_c is offline
Re: Re: reverse lights dont work
Mine has been out for 4 years now on my 96. It is a manual transmission. I know for a fact that it is the switch on the side of the tranny. I was able to get the wiring harness plug to come off the switch. When I turned the key onn and shorted across the wire, I got lights. I checked the switch and was never able to get the switch to close. The unfortunate part is that replacing the switch on mine involves dropping the tranny, you can't get to the bolt that holds it in. I'll replace it when the clutch goes.
If you can get it working, I would also recomend a relay for your 2nd set of backup lights.
