Old 04-16-2004, 11:54 AM
99GTPGIRL 99GTPGIRL is offline
DIC Module for 99 GTP
Hey everyone.
I am in need of some info. I have a 99 GTP, and my DIC has gone out because of an electrical failure in the car (don't ask).
I am looking for the part number of the DIC Module so that I can replace it in my GTP.
Also, does anyone recommend better rotors than the current stocks on the car that I have?
Thanks.
Old 04-17-2004, 03:25 AM
GTPgirl's Avatar
GTPgirl GTPgirl is offline
Send a message via ICQ to GTPgirl Send a message via AIM to GTPgirl Send a message via Yahoo to GTPgirl
Re: DIC Module for 99 GTP
I've always been pretty happy with my stock rotors...but I kinda have been wanting to upgrade to Baer brakes. I haven't done much research, not sure if they have rotors for the GP's, and if they do, they're a hair on the expensive side.
GTPgirl
Black 1998 Camaro - currently driving
Black 1999 Grand Prix GTP - burned March 2008
Plum Crazy 1970 Dodge Challenger - work in progress!
Old 04-18-2004, 08:51 AM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
I have installed slotted/drilled thru rotors and the car breaking performance improved substantially, you do not have to mod anything else, just install these rotors and you can use the OEM pads and calipers. I found them at E-bay. And if you go to http://www.worldparts.com and with your VIN number do an inquiry they will give you quotes and part numbers based on your part description, This is for the DIC module Hope this helps
Old 04-18-2004, 05:32 PM
GTPCatz GTPCatz is offline
Banned
I would Upgrade to F-Body Calipers and 12" Brake Rotors....I will be doing this soon and have heard there is a big diferance in stopping power...
http://www.clubgp.com/newforum/tm.asp?m=1211570
Old 04-18-2004, 05:39 PM
Banned
and your original Question
DIC with traction control button:
16200975
Old 04-20-2004, 11:13 AM
erjulian erjulian is offline
Originally Posted by 99GTPGIRL
Hey everyone.
Thanks.
I would go on EBAY and find a used DIC, a Dealership will charge you way to much and the installation is quick and easy do it yourself project. just remove 2 screws below the steering wheel and pull on the plastic dash housing and it will pop out alowing you access to the DIC.
Old 04-22-2004, 11:01 AM
kilroypr's Avatar
erjulian, there is an issue with buying used electrical parts. They might have been selling them on the first place becaue an intermitent problem. The best way to go if to get it knew and install it herself.
Old 04-22-2004, 11:33 AM
Re: Re: DIC Module for 99 GTP
I bought one used for 50 bucks and it works perfectly. If you went new it may be a lot of money through a dealership. Also try junkyards.
