Hi---I'm new here and desperately seeking help.
new owner of a 98 Jetta GL - 130km's. If it sits for more than 8 hours on a cool day/night...it takes several attempts to start. It sounds/feels like not everything is firing. Checked plugs - ok. Replaced sensor, new starter, new coil. Check timing - ok, replaced belt. Still, same thing every morning. It turns over but does not completely kick in. I'm new to VW and I love the car...when it starts! This has been ongoing for 5 months. Any suggestions/ideas? |
Re: 98 Jetta slow startinf
Which engine do you have? Does it crank normal (not slow), but not start? Has the battery been checked? How long do you crank each time, & how many attempts? Does the check engine light come on? What sensor was replaced & why?
Re: Re: 98 Jetta slow startinf
I'll assume they used the correct platinum spark plugs. Have they checked the fuel pressure, particularly that it holds about 30 psi fuel pressure for at least 10 minutes after shutdown. Also you might want to pull some plugs after it has sat for about 20 minutes & see if it is wet with gas, perhaps an injector is leaking & flooding the engine. Does the engine run okay before it warms up (cold)?
