Locker for 2000 ranger xlt
Any one know if/where you can get a locker for a 2000 ranger xlt w/ 7.5 rear end with out swapping whole axle?
1 wheel burnouts SUCK!!! |
Re: Locker for 2000 ranger xlt
you can buy an air locker from summit racing. best option cause you can unlock it for normal use if you ever plan to use it for normal use other than burnouts.
you can fix it really easy....just weld ur spider gears and side gears together....lol, but yeah summits locker is the best choice
yeah... don't weld it!!!
also, for a cheaper option, check out Lock-Right ... "The LOCK-RIGHT's operation is fully automatic. Designed to send the engine power to the wheels with the most traction, the LOCK-RIGHT will help get you where you want to go. While traveling straight the LOCK-RIGHT will lock the axles together similar to a spool. However, when the wheels need to differentiate in a turn, the LOCK-RIGHT will allow the outside wheel to rotate faster to complete the turn. The internal gears on the LOCK-RIGHT will overrun each other to allow this differentiation. " - http://www.powertrax.com/lockright.html
If it moves and it shouldn't, use duct tape. If it doesn't move and it should, use WD40. |
