Old 04-16-2004, 01:44 AM
93fordf150 93fordf150 is offline
Angry Intake manifold leak
I have a 93 f 150 w/ a 5.8 lt in it I was wondering if i have a intake leak. When I take out my spark plugs I can smell gas/oil mix. Would that be a simple fix or would it be something more complex?
Old 04-16-2004, 08:23 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: Intake manifold leak
more likely a leaking fuel pressure regulator or some injectors or bad sensors causing it to run very rich
Old 04-18-2004, 12:31 PM
97chevyman's Avatar
97chevyman 97chevyman is offline
Well, have you changed your oxygen sensors yet? I change mine every 80K. Try some new plugs, new upstream oxygen sensors ( before the convertor ), change your fuel filter, run some good injector cleaner (seafoam or Marvels mystery oil) and give it a shot. If your o2 sensors are bad, they will get carbon build up on them, and not read the correct oxygen reading, usually not enough oxygen, so the PCM module will richen the motor up.
Intake Manifold Gasket End Seals bjaymo3 Grand Prix 5 07-30-2010 09:29 AM
Replace Intake Manifold Gasket Stammtra Cougar 4 07-20-2010 01:13 AM
2002 2.7L Intake manifolds ksparticuspa Intrepid 1 07-02-2010 03:25 AM
Intake manifold leaking... Regin8r Montana/Montana SV6 4 10-04-2009 01:31 PM
exhaust leak fixed. intake manifold leaking! ghostrx7 RX-7 2 04-22-2005 12:10 PM
