Old 04-15-2004, 06:39 PM
JZA80_Driver JZA80_Driver is offline
Aftermarket pulley options for 3.8's supercharger?
This is actually going on a 95' Buick Riviera, but the Buick guys never reply to anything.
Anyway, just want some more low-end power out of my 95' 3.8 S/C. Motor has over 120K on it, but compression tests out nicely. Will also probably do a chip and exhaust; suggestions are more than welcome. Thanks.
Old 04-15-2004, 07:02 PM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
Re: Aftermarket pulley options for 3.8's supercharger?
http://tacgp.clubgp.com/vendors.html
Any of the pulley systems that those vendors offer will be good.
For starters, Get a 3.4 pulley
DHP/CYA RACING/INTENSE all have PCM's now
Hit up www.clubgp.com for a wealth of info
Old 04-16-2004, 06:31 AM
andyd00 andyd00 is offline
Re: Re: Aftermarket pulley options for 3.8's supercharger?
Dont forget to borrow the pulley puller. Don't use a steering pump pulley puller.
Old 04-18-2004, 10:37 AM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
Well there are many sizes. 3.4", 3.25", 3", 2.8". The smaller the pulley the more knock it will generate if the intake is to hot. So make sure that you cool the intake more the smaller the pulley is. FOr starters get the 3.4"
Old 04-18-2004, 05:55 PM
GTPCatz GTPCatz is offline
Banned
Make sure you check out those thunder pullies!
and all because you have a kickass intake dont think you can drop to a 2.8 pulley....alot of work will be needed to the rest of your engine before you can drop away from the 3.4.
The 3.4 would be a good starter for you.
Old 04-18-2004, 08:54 PM
Cool, thanks guys. I found a guy that can machine one for me for 30 bucks; I'll tell you the results.
Old 04-18-2004, 11:31 PM
kilroypr's Avatar
thrasher pulleys
