Old 04-15-2004, 05:58 PM
OsiriS16 OsiriS16 is offline
S-10 V-8 Engine Swap HELP!!
Hello All,
I just inheirited a '96 S-10 from my gradfather. Just started looking at performance stuff for it and realized my little 2.3L p.o.s. isn't gonna get me anywhere... any help or suggestions as to a V-8 to swap in or tranny for the V-8 would be greatly appreciated...along with any suggestions as to how much $$$$ im looking to spend....i don't care how much...just looking for an idea (below lik $10k)
OsiriS16
Old 04-16-2004, 10:32 PM
jmc3 jmc3 is offline
Drop a ls1 or lt1 with a 6 speed transmission in it and then you be going at it like only a few others. If you search the web there is a company out of texas that will seel the wiring harness to match up to your stock harness and the mounting should be easy because there a few people out there that have shoehroned them in because the motor mounts are the same on a 350 as they are on a 4.3l v-6. The only fabrication will be a new cross member for the transmission and to get the drive shaft shortend. I thought about doing the swap to a v-8 but I think that I am going to build my 4.3l and turbo charge the crap out of it.
Old 04-16-2004, 10:34 PM
By the way you could probably get away for under $5 to 6k with it done right.
Old 04-17-2004, 05:21 PM
madcatter madcatter is offline
Basically, the stock setup for a 4.3 will work with a small block except for length related issues (rad. shroud, etc.). The stock T4 4-speed in my 4x4 was the same length as a 350 turbo, mounts all lined right up.
Old 04-18-2004, 12:15 PM
cuttman80 cuttman80 is offline
Re: S-10 V-8 Engine Swap HELP!!
Originally Posted by OsiriS16
Hello All,
OsiriS16
hey guy
well the engine swap for a 4 cyl was hard but i did check out hedman hedders for the s10 v8 swap. the drive shaft was about 250 to make it customize. good luck with getting a fan to work
Old 05-28-2004, 02:56 PM
tiltthe63s tiltthe63s is offline
Send a message via AIM to tiltthe63s
I have seen some people with a 350 and they put the radiator on oposite side of header and went with dual electric fans instead of belt driven, got to keep that beast cool
Old 05-28-2004, 02:59 PM
this is really huge but makes you wish u can drive at least once http://www.v8s10.org/gallery/view_ph...ed&id=interior
Old 06-03-2004, 02:20 PM
dugie6551's Avatar
dugie6551 dugie6551 is offline
I put a 350, carborated motor in my 87 GMC, for around $2,000 (including $300.00 for motor). I did not use any kits, because they tend to be more trouble the their worth.
The usual fabs: new tranny mount, shortened driveshaft ( one piece ). Use a short shaft waterpump, electric fans help. I used exhaust manifolds off a 305 chevy (camero I think), heavier front springs. Oh yeah, I almost forgot, GAS MONEY !!!
Old 06-03-2004, 02:59 PM
TopDogg TopDogg is offline
Go with fuel injection my camaro gets 22mpg my s10 gets 14mpg
Old 06-06-2004, 10:51 AM
willsv8's Avatar
willsv8 willsv8 is offline
go to blazinlow.com all the info there to do v8
Old 07-29-2004, 08:56 PM
SwampFoxS10 SwampFoxS10 is offline
Another place to look at for V8 swaps: http://www.leeshightechtrucks.com - they're out of Fla.
