Originally Posted by Toban
 I've received a verified keyless remote for my vehicle and received a sheet with about 8 different sets of directions on how to program it.
What I would like to know is the correct procedure for the setup for the first time. This information would be greatly appreciated , thank you...
Clark Robbins
1995 Chrysler LHS
[email protected]
UPDATED & IT WORKED
Method C was successful . Remove center bezel, unplug traction control plug, locate pin 1 and 4 ( they are the 2 pins furthest away from the vertical alignment pin for the socket , I will be happy to supply a picture of this ) used a paper clip spread open and folded in half. turn key on as far as it would go with out starting car, placed the paper clip into slots 1 and 4 the power locks should cycle to let you know it's in learn mode (note if there is no pin 4, you don't have keyless remote option in that car) then while keeping the jumper in the pin 1 and 4, press any button on the remote for a second or two till the locks cycle again. Unplug the jumper, turn key off, try the remote, worked on mine, took all of 3 minutes to pop off the center and set it up. Hope this helps some one, enjoy...
