Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
View Poll Results: How do you rate this Thread?
1=Bad 0 0%
2=Fair 0 0%
3=God 0 0%
4=Excellant 0 0%
Voters: 0. You may not vote on this poll
Old 04-15-2004, 01:35 PM
billg226 billg226 is offline
97 Lumina LS Keyless Remote Programmng
Hi Group, new member here:
How do I program a new keyless remote for my 97 Lumina LS?
Thanks,
Bill
Old 04-23-2004, 06:35 AM
spotco2 spotco2 is offline
Banned
Re: 97 Lumina LS Keyless Remote Programmng
Transmitter Programming
Perform this procedure when any of the following conditions exist:
The RKE programming connector (BLK/WHT wire) is grounded (CKT 1455).
The RCDLR is replaced.
A keyless remote transmitter is replaced.
A second (up to a total of 4) keyless remote transmitter is added.
Programming Procedure
Important
If the vehicle has more than one keyless entry transmitter, ensure that all of the keyless entry transmitters are programmed during the same programming sequence. Any keyless entry transmitters that are not programmed will not work correctly.
Open the rear compartment lid.
Pull aside the right side compartment trim in order to gain access. Refer to Compartment Side Trim Replacement - RH Rear in Body Rear End.
Use a jumper wire with alligator clips in order to ground the RKE programming connector. The door locks will lock and unlock. This action indicates that the RCDLR has entered the keyless entry transmitter programming mode.
While the programming connector is still grounded, program each of the keyless entry transmitters, one at a time. Press and hold the LOCK and UNLOCK buttons simultaneously on the first keyless entry transmitter. Hold the buttons for 10 seconds. The door locks will lock and unlock. This action indicates that the keyless entry transmitter has been programmed.
Repeat Step 4 for the remaining keyless entry transmitters. You may program as many as 4 keyless entry transmitters.
Remove the jumper wire from the RKE programming connector terminal.
Verify that the keyless entry transmitters operate correctly.
Install the right side rear compartment trim. Refer to Compartment Side Trim Replacement - RH Rear in Body Rear End.
Close the rear compartment lid.
Old 04-23-2004, 10:29 AM
Thanks for your help spotco2. What is the RCDLR? I know RKE=Remote Keyless Entry.
Bill
'98 Lumina Keyless Remote Programming - How To? citpaj Lumina 26 10-02-2013 12:28 PM
Program 2007 camry keyless remote marty.graw Camry/Camry Hybrid/Vista 1 03-31-2010 08:13 AM
chime indicating keyless remote error - 2003 Pontiac Grand Am Jcolli06 Grand AM 1 02-18-2009 06:37 PM
96 Lumina Keyless Remote Programming.. Help please! BigJoeW Lumina 13 10-01-2005 08:46 PM
Lumina Keyless Remote Programming citpaj Lumina 8 07-22-2005 05:43 PM
