Old 04-15-2004, 05:01 AM
mel_carramel's Avatar
mel_carramel mel_carramel is offline
Send a message via MSN to mel_carramel Send a message via Yahoo to mel_carramel
Help on Thinner... HOW to is not included..
Hye all.. i have a problem.. i tried most of my hobby shops around my area searching for tamiya thinner to be use to dilute my paints for air brushing... and guess what?? its out of stock till next months!
i cant wait that long.. so can anyone help me? i bought some ordinary thinner from hardware shop.. anyone can help me how to dilute those thinner to be able to use it for tamiya acrylic paints... and so it wont eat my plastic parts.??? pleasee...
someone around the shop suggest me using carosine.... is it possible??
Pls.. i need a hand.. thanks all~!
btw.. i just got myself a new box of Supra! hehehe.. and i bought some other stuff... too
Old 04-15-2004, 05:08 AM
TanKaBoY's Avatar
TanKaBoY TanKaBoY is offline
Re: Help on Thinner... HOW to is not included..
u could buy them online
Completed:
Sexy Iwase Kyoko's FD3S RX-7
Apexi D1 FD3S RX-7
Old 04-15-2004, 05:10 AM
i wish i could.. i dont have credit card...
Old 04-15-2004, 05:17 AM
935k3's Avatar
935k3 935k3 is offline
Do not use regular paint thinner with Tamiya acrylics. Just get some isopropyl or denatured alcohol.
Old 04-15-2004, 05:36 AM
TanKaBoY's Avatar
dont ur parents have a credit card? just use that
Completed:
Apexi D1 FD3S RX-7
Old 04-15-2004, 06:33 AM
sadly no.. my parents doesnt... and what is isopropyl or denatured alcohol???? can someone tell me? where can i get those?
Old 04-15-2004, 07:59 AM
ZoomZoomMX-5's Avatar
Tamiya acrylic may thin with several options. Test them first!
Rubbing alcohol (isopropyl). This is available everywhere.
Windex. I know it cleans the airbrush very well after spraying Tamiya acrylic, but I don't know if it mixes well.
Lacquer thinner. Same as above, it cleans the brush very well, and I know someone who mixes just enough lacquer thinner to get it to spray, so it works for someone.
Remember, test these first to see what does/does not work for your setup. Do not use enamel thinner or kerosene!
My Fotki Album
Old 04-15-2004, 08:01 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
DO NOT USE PAINT HARDWARE STORE PAINT THINNER FOR ACRYLICS.
Acrylics are water based, not oil based. The thinner you got at the hardware store is suitable only for enamels- nothing else.
To dilute acrylic paint for airbrushing- Tamiya, Gunze, MM Acryl, etc:
Go to a drug store or grocery store, and go to the first aid supply section. Get a bottle of isoproplyl (rubbing) alcohol. It's cheap, probably less than $1 USD. Then, get youself a bottle/jug of distilled water. It's cheap also. Mix a thinning solution of 1:3 isopropyl alcohol:distilled water. To clean your airbrush, use Windex or similar glass cleaner- just don't use generic stuff, it usually doesn't have enough ammonia content.
Then, when your LHS gets Tamiya acrylic thinner, open a bottle and smell it. Smell familiar?
Old 04-15-2004, 11:46 AM
MPWR.. ur a genius~! thank you.. thank you so much.. another thing.. about putty.. can i use else then tamiya putty?? i saw some putty in the hardware shope.. but it says for fibre.. woods.. and etc.. but didnt mention anything bout plastic.. what happen if i use it??
Old 04-15-2004, 11:49 AM
another thing bout this windex.. what are these? what does it do? where can i get those? i usually clean my airbrush using water.. is that dangerous???
please.. i need help.. does anyone wanna see my air brush?? ill post the pic after this..
Old 04-15-2004, 11:59 AM
jswillmon's Avatar
jswillmon jswillmon is offline
Send a message via AIM to jswillmon
windex is a brand of window cleaner in the States, not sure if it is in other countries, basically any window cleaner with amonia.
water will clean an airbrush just not as well as other things like alcohol, thinner or windex.
I would not use that putty, i can probally assure you it won't dry hard enough to do anything with. Just search this board to check you other alternatives for putty.
The Name's Jesse!
**Click the pic for my latest build, Daytona Blue 350z**
Old 04-15-2004, 12:04 PM
ok cool.. thanks jswillmon... ill search for a window cleaner with ammonia... is that what u mean rite??
uhmm... another thing.. this epoxy putty.. how am i suppose to use it? why is there 2 type.. one is white and the other is kinda yellowish orange.. whats the diferent?
Old 04-15-2004, 12:11 PM
jswillmon's Avatar
i'm not sure about the putty, i'm sure someone else with more experience with it can help you.
Like mpwr said windex has more amonia than the cheeper brands. Look for it or look for another name brand that will be your best bet.
The Name's Jesse!
Old 04-15-2004, 12:27 PM
supermod04's Avatar
supermod04 supermod04 is offline
Banned
Send a message via AIM to supermod04 Send a message via MSN to supermod04
yea i had that problem with harware store thinner and arylic! i use just cheapo crap from the hardware store for my enamals
Old 04-15-2004, 02:29 PM
MPWR's Avatar
What brand of epoxy putty do you have? Epoxy putty almost by definition is a two part affair. You mix equal amounts of both parts, and kneed it THOROUGLY until the putty is one solid color. Shape as you would modeling clay, and let it cure for a day or so until hard.
The hardware store putty you're describing sounds like wood filler. It could be made to work, but then so could wall plaster. Better to stick with the real stuff.
Any ammonia based glass cleaner will work- it's usually clear blue in color, and comes in a spray bottle. It will disolve most acrylics (so don't clean your models with it!), and this makes it terrific for cleaning your airbrush. Water won't clean paint that has dried inside the airbrush spray and siphon assemblies (a bit of it will accumulate and dry on inside surfaces even as your spraying)- it will just wash wet paint out, and the airbrush will eventualy clog from dried paint.
