Go Back   Automotive Forums Car Chat > Chevrolet > Chevelle
Old 04-15-2004, 12:50 AM
bigdaveangell bigdaveangell is offline
gear ratios
Ive got a 71 chevelle with a 350 motor and tranny and I was wondering what kind of gear ratios I might have in the tranny and diff. What did it come with stock
Old 04-25-2004, 05:24 AM
e3j1c1 e3j1c1 is offline
Re: gear ratios
10 bolt or 12 bolt?
Old 06-10-2004, 09:51 AM
skiman762 skiman762 is offline
Re: gear ratios
On the axle tube on the front side is a set of numbers.
you can decode if it is stock
also if it's not posi you can jack one wheel up mark the drive shaft and tire make one turn on the tire and count the turns on the drive shaft
you can a good I idea that way 2.5 turn 2:56 2.75 turns 2:73 and so on
the only true way is pop the cover and count teeth.
My guess if it's a plain jane is 2:56 or 2:73
Powerglide 1.76 1.00 - - - - 1.76
Powerglide 1.82 1.00 - - - -
TH350 2.52 1.52 1.00 - - - 1.93
TH400 2.48 1.48 1.00 - - - 2.00
Don't get talked into swapping to a th400
unless your making more the 500hp not likly for most street small blocks
I know there are some but the same car will always run better times with the th350 due to it lower 1-2 gear ratios.
If anyone question the strengh of a gm trans there are guys running 9 sec powerglides so it can be done.
Old 11-18-2004, 03:28 PM
Mr. Horsepower Mr. Horsepower is offline
Ok if it is a malibu it has an 8.2 rear with 2.56 gears and a one wheel wonder. That is if it is stock...
