Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 04-14-2004, 11:21 PM
ViewtifulCivic ViewtifulCivic is offline
Send a message via AIM to ViewtifulCivic
Engine Swap Question
I own an 89 Honda Civic HB. It's not an Si or DX, just plain civic. I was wondering which engines I could dump with little or no hassle. I was looking at a JDM B16A SiR1 V2 but I would like more power. What other engines will work? Will a type R?
Old 04-14-2004, 11:31 PM
BOOTY023 BOOTY023 is offline
Banned
Re: Engine Swap Question
what is your stock engine?
Old 04-15-2004, 12:03 AM
I'm pretty sure it's a D15A.
Old 04-15-2004, 12:34 AM
salbaje salbaje is offline
Send a message via AIM to salbaje
depending on your budget. Let me know what you will be wanting to spend then you can decide on which swap to drop in
Old 04-15-2004, 12:18 PM
Tranzlogic Tranzlogic is offline
Send a message via AIM to Tranzlogic
A jdm b16a1 will drop in for about 1300 where a Type R is gonna run you about 4-5,000. Its a big price diff. but your going from a 160hp cable tranny to a 200hp high compression LSD tranny !both will need a mount kit and shift linkage to drop in. Altho the linkage usually comes with a full swap. there are a few good choices in between, like sal said its all a matter of your budget and what you want to get out of the vehicle.
Old 04-15-2004, 06:41 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
if you want a straight drop in, get yourself either a DOHC ZC(130hp) or the JDM D15 VTEC(around 130hp)
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 04-16-2004, 12:13 PM
Well, let's say I'm willing to pay $5,000. Then if I have all the necessary equipment, such as shift linkage, ecu, tranny etc., then I can dump the Type R?
Old 04-16-2004, 01:23 PM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
You'll still have to wire for VTEC and the Type-R transmission is hydraulic - you'll have to make a conversion to use the hydraulic transmission.
A first generation B16A will have a cable transmission and will be a more practical engine budget-wise. I would pick that or the DOHC ZC motor personally.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 04-20-2004, 12:41 PM
jdmcrxhatch jdmcrxhatch is offline
Send a message via AIM to jdmcrxhatch Send a message via Yahoo to jdmcrxhatch
B16a1 one is best...
I am asian i have enough rice in my basement i dont need anymore on the street.
JDM YO w00t w00t.
about domestics
Old 04-21-2004, 12:22 PM
89stdzc 89stdzc is offline
Send a message via AIM to 89stdzc
i'd suggest if you honestly have 5g's to drop in do the b16a1 and do some internals. so you don't lose any streetability. if you are like the majority of us and only have what you make and a few extra bucks. drop in the zc and put a turbo or 50 shot of juice you won't be disapointed either way.
Also you sound like you have the 4 speed STD you'll have to swap out steering hubs and knuckles to do any swap cause the axels won't fit. and you'll have to do the wiring..... zc wiring is not too bad nor is the b16. the zc takes about 2 hours start to finish the b16 takes like 3.
Don't forget you'll want to get a better exhaust since your pipes are like 1 1/2 inch and the extra's that can cost up to 1000 just to make it run well on a budget. do it right so you don't get a money eater nor a piece.
i'd suggest the d15 Jdm vtec i've never done the swap but i've seen a car with it and it runs well
