Old 04-14-2004, 10:52 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
Angry Gahhh!!! Alarm Again!!!
yep connected my alarm up again after being disconnected for over a month, re did the wiring under the dash for the ignition wire and nope! still doesnt work, still goes off when i drive and its really pissing me off
can someone provide a pic of what ignition wire it is that you connect the yellow wire from the alarm to? the one that senses that the ignitions on so it wont go off when your driving causing you to go insane!?!?!!?
that would be VERY much appreciated, thanx
its weird cuz its worked for almost a year, nothings been changed, i install some foglights and it decides it wants to be gay and screw up on me the same day and i didnt cross any wires either, so i need your help asap!
Old 04-15-2004, 12:14 AM
travagliante's Avatar
travagliante travagliante is offline
Re: Gahhh!!! Alarm Again!!!
Um i dunno on mine there is several wires to tell if the engine is on.
Check the oil sensor, brake lamp, ignition, acc wire, negative door trigger. Sorry cant help much.
Most likely the ignition wire by the key came undone, thats the reason why mine would always go off when i was driving.
Old 04-15-2004, 08:10 AM
1PhatCX's Avatar
Re: Re: Gahhh!!! Alarm Again!!!
thats the wire i fixed yesterday!
but it still does it so i'm wondering if its connected to the wrong ignition wire
Old 04-15-2004, 09:24 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Anyh wire that shows 12+ when the car is on is a good enough source for ignition. I wonder if the way you hooked up the fog lights is somehow back feeding into the alarm?
Old 04-15-2004, 01:24 PM
1PhatCX's Avatar
i've tried disconnecting the foglights and the alarm still acts gay!
so if you can show me a pic of where on the ignition to connect that wire it would be good
Old 04-15-2004, 11:45 PM
Like I stated before, ANY wire that shows 12v+ when you turn the key on is OK. I think it is black/yellow??? Anyway, what brand is the alarm? I also need to know what you mean that it goes off??? Do you mean it arms itself and then gets triggered into full alarm? Or does the siren sometimes go goofy and make alot of noise but not really like it's armed? I would also double check the 12v constant and grounds to make sure they are correct and not loose. Some cheaper alarms will go into full trigger mode when as soon as you hook up power and ground.
Old 04-16-2004, 12:03 AM
sofast's Avatar
sofast sofast is offline
Send a message via AIM to sofast Send a message via MSN to sofast Send a message via Yahoo to sofast
the wire you are looking for is black/yellow on the ignition harness. What brand of alarm do you have? If you dont get it figured out let me know.
Old 04-16-2004, 01:33 AM
Ignition harness, its the black wire with a yellow stripe. Did you cut it and hook the alarm between it with the relay?
When you hooked up your foglights was the ground wire touching the 12v bec. that would be putting power to all the grounds which would cause it to go off.
Old 04-16-2004, 08:35 AM
1PhatCX's Avatar
the alarm is a crime stopper unit, i'm gonna get rid of the foglights and see if that helps
also, the siren will go off for like 2 - 4 seconds and then u can hear the car arming and dis arming and it does this like 4 or 5 times then after a few mins it'll do it again, i dunno what the hells going on
Old 04-17-2004, 08:47 AM
1PhatCX's Avatar
i think its fixed, i said fuck it and returned the foglights cuz i've only had them on for a month, i was driving around lastnight and everything seemed fine! I'm happy...... for now
Car Alarm Repeatedly Going Off AlxBlack17 Taurus | Taurus Wagon 1 03-01-2010 07:48 AM
Unknown alarm system replacing remote Football42008 Engineering/ Technical 6 01-17-2010 11:44 PM
1997 Tercel alarm resets when battery disconnected Simstim Tercel 3 01-10-2010 03:36 PM
auto theft alarm skelou What do you want to know? 0 09-22-2009 12:01 PM
Alarm question again Turbo6 3 Series 0 12-20-2002 04:28 AM
