Go Back   Automotive Forums Car Chat > Dodge > Avenger
Old 04-14-2004, 09:50 PM
pimp_squeak's Avatar
pimp_squeak pimp_squeak is offline
Send a message via MSN to pimp_squeak
AWD avenger
not that I'm planning on doing it, I mean I'm only 16 and I dont have a car yet...but would it be possible to install the eclipse AWD system into an avenger...under the skin they are the same vehicle correct?if you can would the 3.0 V6 work with it or is the system too weak to handle the power? thanks for your time
Old 04-20-2004, 10:19 AM
Re: AWD avenger
nobody have an answer?
Old 04-23-2004, 09:58 AM
Re: AWD avenger
I'll take that as a no.....if anyone finds this and is thinking about replying don't bother, I've moved on to bigger and better things
Old 04-29-2004, 10:31 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: AWD avenger
Well, you could do it.
Old 04-30-2004, 01:00 PM
Re: AWD avenger
........details?
Old 04-30-2004, 09:46 PM
BleedDodge's Avatar
Re: AWD avenger
Well first you need a donor Eclipse. I'm not going to type a whole detailed paragraph for a dreamer.
Old 06-27-2004, 07:05 PM
waukon_indian_qb waukon_indian_qb is offline
Send a message via MSN to waukon_indian_qb
well i am wondering about the same thing and i already have a talon tsi donor car and i would do it if someone would let me know what all it would take, any info would be much appreciated
Old 07-01-2004, 05:09 PM
viper2pt0's Avatar
viper2pt0 viper2pt0 is offline
It has been done......a member over at ASOG (www.asog.net) in the forums did it. He had posted alot of pics and such, IT WAS FAR FROM A BOLT ON PROJECT. it took alot of fabrication, and modification of the avenger and donor parts. I believe he used the entire drivetrain (front and rear) as well as motor from a gsx. either way it took alot of time and money. i will post the link if i can find it.
Old 07-01-2004, 05:12 PM
viper2pt0's Avatar
Re: AWD avenger
http://www.asog.net/viewtopic.php?p=435024#435024 here ya go. If you search you can prolly find a few diff. threads about it.
Old 07-21-2004, 11:25 PM
Re: Re: AWD avenger
thanks for the help viper, this might be just what im looking for
v70 awd starting problem hot and cold jonnylove V70 0 05-13-2010 05:04 AM
AWD Rear End NOISE BigBriar63 Rendezvous 1 05-10-2010 11:59 PM
94 Astro AWD - front brakes? stan_5150 M Bodies 2 04-06-2010 08:47 PM
AWD Avenger nitrohemione Avenger 2 05-12-2005 07:47 AM
want to see the awd avenger? im all in Avenger 1 11-27-2004 05:57 PM
