Old 04-14-2004, 05:21 PM
Kidokan Kidokan is offline
Question 88 motor applications
new to the world of camaro's am curious what can be used to replace my 305 thanks
Old 04-14-2004, 06:45 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: 88 motor applications
any small block. a 350 or 400 would be perfect. you'll probably have to change the manifolds if you throw in a motor with older heads because the bolt on the passenger side closest to the firewall is further back. but a set of headers would solve this. another problem with those cars is body twist if you drop in a torquey motor without reinforcing the rest of the car. also the 7.5" diffs blow up rather easily.
Old 04-14-2004, 10:59 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
not sure about that bolt on the passenger side head thing, but the center bolts in the heads are at different angles. any small block is identical on the outside with the exception of the dipstick being on the passenger side on post 87 blocks. internals are pretty much the same too except the rear main seal and roller cam in 87 and up blocks
Old 04-14-2004, 11:15 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
actually the dipsticks are on the drivers side on 87 and older engines
Old 04-15-2004, 12:09 PM
4onFloor's Avatar
that's what i meant by the dipstick on post 87 blocks. pre 87 have dipstick on driver's side
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
