Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 04-14-2004, 05:04 PM
l4dom l4dom is offline
Power trunk problem
The power trunk on my 1999 Jetta GLS has stopped working. If I use the key I can hear the power motor run but the lock does not disengage. The same thing happens if I use the power trunk switch on the drivers door. The key worked sometimes but now not at all. Any ideas where to start looking?
Thanks
Old 04-18-2004, 04:08 PM
Does noboby have any idea what the problem is?
Old 04-19-2004, 10:42 PM
boschmann boschmann is offline
Re: Power trunk problem
If all the other doors lock/unlock properly, then concentrate on following the vacuum hoses in the trunk area.
Old 04-20-2004, 09:17 PM
After folding down my back seats and crawling into the trunk from the inside of the car I managed to open the trunk by manually turning the latch. Upon inspecting the latch I noticed the cable that unlocks the latch was broken. Thats why I could here the motor but the trunk would not open. I re- attached the cable and the power trunk works perfectly.
