OBDO to OBD1 Distributor Color Wiring,HELP!!
I just got the OBD1 Distributor plugs and as i matched the color wires up against my OBDO Distributor plugs all but 2 sets of wires match up,I have 2 white left over on OBDO and 1 white,1 yellow with a green stripe on the OBD1.which white on the OBDO get's the yellow with a green stripe? this is the big plug we are talking about,the little plug had 2 wires and the colors did match.
SOLD!
That's exactly what i did (all but those set of wires i mentioned above don't match).
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. My first Civic love Died from 92 year old Fart not watchin out.
Nope nothing on their about rewiring distributor, yes i'm going obd1 and using a p28 i already have the ecu conversion harness.
Bump.....
Re: OBDO to OBD1 Distributor Color Wiring,HELP!!
I know wut ur talking about. I had to do it for my z6 swap before. Gimme a sec and i'll get u the answer.
ok.....
if you look at ur stock wiring harness, there are 2 white wires. You have to look extremely closely to notice this but one of those white wires is bigger/fatter than the other. This fatter white wire goes to the yellow/green wire on the obd1 dizzy. The thinner white wire goes to the white wire on the obd1 dizzy.
Thanks BAm BAm i know exactly which wires you are talking about the fatter white wire goes to the green/yellow and the other 2 white go together(hope this works). BTW would you happen to know what other plugs i need to change? also i heard that i can use my resistor box with the obd1 injector plugs(i already shaved off the plastic little pieces that stopped the obd1 injectors from fitting into the obdo injector plugs).
Hi i hope someone can help me asap! obdo to obd1 distributor wiring, the 2 white wires on one side and yellow/green and 1 white on the other side, and that i had to look really careful one white wire is fatter than the rest and that one goes with the green/yellow well i did that but their was a problem with the 2 white ones left over if connect them the car won't stay on if i disconnect them the will stay on and idle fine, any idea?
Bump ,need Help Please.....
are they the two that plug up to the cam sensor
i dont rember right off which olors they are but the two extra should go to that sensor you have to splice them in |
Re: Re: OBDO to OBD1 Distributor Color Wiring,HELP!!
so is there any way to rewire your obd0 distributer or do you have to do it with an obd1?????
you have to go obd1 dist. there should only be 2 white wires. 1 goes the obd1 white wire and the other goes to the obd1 yel/grn. idk what your talking aobut a 3rd white wire for. did you match up all the other wires, color for color ?
if you go with obd1 injectors then you dont use the resistor box. if you want to use obd1 injectors, take the power wire for the resistor box and run the power wires from each injector and tie them into the power wire for the resistor box. this eliminates the resistor box and correctly wires your injectors |
also, you can't use an obd1 distributor unless you convert to obd1 and use an obd1 ecu.
