Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 04-14-2004, 10:49 AM
jhern jhern is offline
how to add a new keyless entry remote
I have a 2003 chevy impala. it has a factory Keyless entry system. Now when i purchase this vehicle they only gave me one remote so i purchased a new remote for it. Now that i have it i would like to find out if you can help me by telling me how to program this remote to factory system. Thanks in advance.......
Old 04-23-2004, 06:31 AM
spotco2 spotco2 is offline
Banned
Re: how to add a new keyless entry remote
Transmitter Programming
Important
All transmitters which are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode it will erase all previously programmed transmitters upon the receipt of the programming signal from the first transmitter. Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle.
Install a scan tool.
Use the scan tool in order to access the Body Control Module (BCM) Special Function: Program Key Fobs.
Press the START soft key on the scan tool.
Important
The scan tool must stay connected until all of the transmitters are programmed.
Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of 5-10 seconds, the locks will cycle in order to confirm the programming of that transmitter.
Repeat the previous step in order to program up to 4 transmitters.
Remove the scan tool.
Operate the transmitter functions in order to verify correct system operation.
'09 Corolla KeyFOB, keyless entry programming Question btrolla Corolla/Matrix/Voltz 1 09-03-2010 12:00 PM
1991 OLDS Cutlass Supreme SL 2-door keyless entry module PAPAJACK Cutlass Series 0 07-31-2010 09:56 PM
94 s10 remote keyless entry programing instructions needed stillblazin Problem Diagnosis 0 07-01-2009 09:39 PM
remote keyless entry problem smity9089 Intrigue 0 04-13-2009 11:45 PM
anyone know how to program keyless entry remote for 96 camry? mylilshellbell Camry/Camry Hybrid/Vista 2 03-06-2004 03:36 PM
