Old 04-14-2004, 10:04 AM
PhReAzE PhReAzE is offline
Send a message via MSN to PhReAzE
CAI HELP Two vacuum hoses
Ok, dumb question, where do i put these two vacuum hoses when installing my cold air intake? also there is a little plastice piece that is threaded on both sides, what do i do with it.
Thanks, Evan
Old 04-14-2004, 07:51 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
Re: CAI HELP Two vacuum hoses
tee em together or something..and stick them on the nipple on the intake... they're just breather hoses...not 100% vital that they're on the intake.... get one of those fancy little small filters for it..
SOLD!
Old 04-15-2004, 01:21 AM
PaSleeper PaSleeper is offline
A: the throttle control diaghragm valve
B: Air Check valve
A: uses pressure from the throttle snapping shut to help stop it from closing violently
B: allows more air in when starting the motor
I'd say A: should be def. connected to the intake, and B: could have a small filter. mine had holes for both
Old 04-15-2004, 10:18 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
just tee them off and stick them into one hole. I'm pretty sure TEG CAI's come with the holes unless it's a cheap brand. If not, drill a small hole, tee it off and stick it in there. Ur car will run without them connected at all, but they are using the air speed in the intake which varies at different RPM's, so they should be connected.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
1987 F-250 351w Vacuum Hose Routing Ijustneedhelp F Series 0 07-04-2010 08:23 PM
Please help on Vacuum hoses for b16a in crx dx!!!!!!! Faded Engineering/ Technical 3 09-25-2002 08:12 PM
jdm b16a vacuum hose HELP/CRX Smug Engineering/ Technical 1 06-20-2002 10:21 PM
