Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 04-14-2004, 08:25 AM
iiicarol iiicarol is offline
Send a message via Yahoo to iiicarol
Question Key Fob For 2001 Aztek
Hello group
I am just getting my Aztek back from the dealer again. Thanks god this time the warranty covered what I needed. I am buying a new key for the Aztek. $43!!!! The said the key fob would $43 also.My question is can I buy a key fob and can I (mechanically stupid) program it? I have looked on ebay and seen some there. But wont do me any good if I cant program it. Any Ideas? I am trying to save some money. I keep giving the dealership too much!!!
Thanks
iiicarol
Old 04-23-2004, 06:30 AM
spotco2 spotco2 is offline
Banned
Re: Key Fob For 2001 Aztek
Programming
Transmitter Programming (Manual Method)
Important
All transmitters which are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode it will erase all previously programmed transmitters upon the receipt of the programming signal from the first transmitter. Up to four transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle. The order in which the transmitters are programmed is important. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. The number on the transmitters are for reference only: #2 can be programmed as #1 or vice versa. Additional unnumbered transmitters are also available. Use care to program the transmitters correctly.
Perform the following steps:
Close the vehicle doors.
Turn OFF the ignition.
Remove the ignition key from the ignition lock cylinder.
Press and hold the driver side door lock switch to the unlock position.
Insert the ignition key into the ignition lock cylinder and remove the key. (Do not turn the ignition key in the lock cylinder.)
Insert the ignition key into the ignition lock cylinder. (Do not turn the ignition key in the lock cylinder.) Leave the ignition key in the ignition lock cylinder.
Release the door lock switch. The body control module (BCM) will sound three beeps in order to verify the Program Mode has been activated.
Press the lock and unlock buttons on the keyless entry transmitter simultaneously for approximately 5 seconds. The BCM will sound two beeps in order to verify that the transmitter has been successfully programmed.
Perform the previous step to program up to four transmitters.
Remove the ignition key in order to exit the Program Mode.
Verify the proper operation of each transmitter.
Old 10-27-2004, 01:34 PM
Cleothecat44 Cleothecat44 is offline
Re: Re: Key Fob For 2001 Aztek
I realize it has been quite a while since you entered this response. I don't know if you have the answer or not to my question. I have a 2001 Aztek that did not come with the remote. Is my car enabled for a factory remote automatically since it has power doors and hatch release?
Any help is greatly appreciated.
Coreen
Originally Posted by spotco2
Programming
Important
Old 12-24-2004, 02:01 AM
2octops 2octops is offline
Geeze, can you believe they banned that Spotco2 guy? He knew all of the programming procedures
Anyways, the easiest way to tell if your vehicle is equipped with remote keyless entry as an option is call the dealership parts dept with your VIN number and they will be able to tell you if it was factory equipped. Your other option is to go sit in the car with the above procedure and see if you can get the car to enter programming mode.
