Gear swap
Sup fellas. Hey i was wondering if anyone could give me an estimate of how much of a difference the 3.73's i am going to put into my car are going make coming from 3.23's, and i mean times wise like 2 tenths or what.
Re: Gear swap
I don't know but i think it is more than just 2 tenths.
Re: Gear swap
No 2 tenths is about right, going from 2.73's to 3.73's you get about 5 tenths and going from 2.73's to 3.23's you get 2 -3 tenths , So I would say 2 tenths most likely if your lucky 3 tenths
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart. Mods: Weight reduction (I don't wear underwear) |
Re: Gear swap
That's it, I thought you'd gain a lot more, isn't going from 3.08s to 3.73 like adding 75HP, that's what I heard. Gears dont even sound worth it anymore
Re: Gear swap
2 tenths is alot , how many mods do you think will show results like that?, also 3.73's are awesome it will feel more like 5 tenths than 2 but if every mod you did added results like that 12's and 11's would be easy
Re: Gear swap
the gears themselves will prolly only add two tenths, but when you combine them with all the other stuff one has, it could be up around 3-5 tenths, which is a noticable difference...atleast thats how i always understood it to work...
Re: Gear swap
Well that was what i was hoping for. I got the Hpp3, 160 degree stat and my Flowmasters so i think thats enough for now since i am in school. ANy body have an estimate on how many carlenghts a tenth is?
Re: Gear swap
the key is gears and a converter. i put the 2800 stall converter in my IROC and shes runnin like a champ, but shes hatin those 2.77's, (Borg Warner rear) when i put in the torsen rear with 3.23 gears, shell wake up a helluva lot more.
Chevrolet Camaro - I enjoy beating the hell out of people http://www.automotiveforums.com/vbulletin/showthread.php?t=68052 |
Re: Gear swap
the gears are just torque multipliers. they will give you a hella of alot more torque and let your engine rev in the higher rpm's faster. theris really no wat to tell in thents an improvement, but your shift points will change. i think for 3.73 you might redline in first at 30mph. oh and make sure you dont need a special adaption kit for those gears. 4.10's need a special install kit but i'm not sure if the 3.73 needs it
Re: Gear swap
The special install kit is only needed when you go from a type 2 carrier (2.73-3.08) to type 3 Carrier gears 3.23's and higher but he already has the right carrier so as long as he doesn't have any rear end damage the basic install kit should do
Re: Gear swap
how much of a difference would it make on my car going from 3.08's to a 3.42 POSI with LSD?
1997 RS 17" Chrome SS Wheels SLP Cold Air Intake Magnaflow Catback Front and Rear Blackouts 20% tint Many More to Come... http://members.cardomain.com/fabolouscam24 |
Re: Gear swap
yeah but the 4.10 need the paddels
Re: Gear swap
um, maybe im wrong, but a posi IS a limited slip differential from what i understand. positraction is an open rear end with clutch packs in it to limit the slip, hence the name. as opposed to a locking differencial that makes the rear end one solid axle shaft. not from experience but from what the other guys are saying, i would say around .2 seconds improovement for those gears as well.
Re: Gear swap
I've heard that echnically Posi is not the same as LSD, but the same effect... and LAD is better, more modern tech.
Re: Gear swap
oh man you all wrong LSD is the best especialy when you see the music! @_@
