Old 04-14-2004, 12:22 AM
*CuTlAsS* *CuTlAsS* is offline
Killed two batteries and one alternator
I've had a problem with my system. I've got the main power fuse hooked up to the positive on the power cap, then from the positive on the cap running to my power on the amplifier. I have my ground from the chassis to the negative on the power cap. From the negative ground on my amp I have hooked up to another ground. Now I believe this is the proper way with a power cap but I've killed 2 batteries and 1 alternator. Is my system hooked up wrong? Am I missing anything?
Old 04-14-2004, 10:12 AM
bmwm3guy's Avatar
bmwm3guy bmwm3guy is offline
Banned
Send a message via MSN to bmwm3guy
Re: Killed two batteries and one alternator
Check to make sure the Lead wire from the main deck is connected right. You might be giving your amp juice all the time even when the car is off.
What kind of car is it?
wait... when you say power cap, do you mean capacitator? because you should not have a ground wire hooked up to the capacitator. Just the Power wire. The ground ONLY goes from the amp to your chassis. This might be why....
Old 04-14-2004, 12:14 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Yes you should have a ground wire hooked up to the capacitor, it sounds like you have it wired right. How much power are the amps drawing, what's your gain set at, and what size is your alternator? A cap is a bandaid, it will NOT help if you have a mortal wound (read: it won't do a damn thing if your amps are drawing way more current than your alternator can provide)
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
