Old 04-13-2004, 11:51 PM
CamBoy CamBoy is offline
Send a message via AIM to CamBoy
Exclamation 94 z28 Camaro Rear end problems
I have a 94 z28 Camaro and at the begining of august last year my spider gears broke, and i have a new carrier and gears put in. I had a richmond 4:10 ring and pinion gear put in, and im not sure what kind of carrier unit. 4 months later a tooth broke off the ring gear, but the gears were sopose to hold up to 450 hp, and i am only pushing 285. The shop ordered some other gears that were sopose to be stronger, but friday i was coming home from a trip and my rear end started whinning. i got it up on a lift at a friends house and found oil on the bottom of the rear end housing. the very back ring on the yoke going into the rear end was away from the housing about 1/8 of an inch. What i am wanting to know is, "Will the stock rear end not support a 4:10 ratio without a spacer?", "Would a Trans am rear end support 4:10 gears?", "would the carrier unit make a difference", "why would the bearings and seals be burning out so easily?" Anyone who can help will be appriciated. thanks
Old 04-14-2004, 01:10 AM
Joseph1082 Joseph1082 is offline
Send a message via AIM to Joseph1082
Re: 94 z28 Camaro Rear end problems
I think it is supposed to be a third series carrier.
Old 04-14-2004, 01:37 AM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
maybe its time to take your car to a different shop
Old 04-14-2004, 11:30 AM
Ok thanks for the help. if any one else has any suggestions then please let me know.
Old 04-14-2004, 07:07 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
yeah, sounds to me like crappy workmanship, if a rear end is set up properly than you shouldnt be having these problems, for the pinion to actually come out from the housing the bolt holding it in place would have to come loose, or not been proporly torqued to begin with, inproper contact pattern and backlash settings would create all the problems your talking about. the stock rear end should handle 4.10 gears and 285hp just fine. take it to someone who knows what they are doing.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 04-14-2004, 07:22 PM
phantomz28's Avatar
phantomz28 phantomz28 is offline
Send a message via AIM to phantomz28
NO. if you go to 4.10 you need to get special spacers/paddels and a few otehr things to help keep the 4.10 in thier. www.slponline.com has the parts you need
Old 04-14-2004, 07:27 PM
89IROC&RS's Avatar
OR i could be wrong and you should do what phantom sez
Old 04-14-2004, 07:31 PM
phantomz28's Avatar
Re: Re: 94 z28 Camaro Rear end problems
Old 04-14-2004, 07:36 PM
89IROC&RS's Avatar
dunno specifics, but i do know ive seen fourth gen camaros running 4.10 gears with no problems. rear end looked stock to me. thats what i was basin mine on. never heard about these spacers and dohickeys.
Old 04-14-2004, 07:41 PM
phantomz28's Avatar
yeah the 4.10 will work on stock rear ends just the mods are inside. so you put those spacers on and it will look stock from the outside ^.^
Old 04-14-2004, 07:57 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
man IROC you've been off your game lately. im a little worried, you feelin ok...
Old 04-14-2004, 09:21 PM
89IROC&RS's Avatar
lol, so there is a noticeable difference huh? in all seriousness, i just switched meds for my ADHD, so i am a bit loopy till my body adjusts.
Old 04-14-2004, 09:24 PM
haha i use to take ritalin or however the fuck you spell it
Old 04-14-2004, 09:30 PM
89IROC&RS's Avatar
thats what im off of, it wasnt strong enough, im on a higher dosage of concerta now.
Old 04-14-2004, 09:36 PM
1992RS 1992RS is offline
Send a message via Yahoo to 1992RS
what gear did you car come stock with? If it was the 2.73 or 3.08 then you'd need a spacer. But if it was stock 3.23 or 3.42 then 4.10 will fit with out a spacer..I think.
