Old 04-13-2004, 11:26 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Turbo Headers?
i just bought a high flow turbo manafold of of ebay and i was wondering if i can bolt it on no questions asked,?,or would i have to change everything like the boost and the fuel ,air/fuel ratio ,ect.....??
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 04-13-2004, 11:31 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
just bolt it on! well you need new gaskets and it would probably be smart to get new bolts, but other than that... bolt that bitch up!
Old 04-14-2004, 01:08 AM
Julioluko Julioluko is offline
Re: Turbo Headers?
yeah, no worries with that, but if you do re-use the old manifold bolts only use 26FT/lbs instead of the 36FT/LBS recomended by the book. Other wise you'll be drilling out broken studs out of the head.
351c Turbo Header construction begins duplox Metal Shaping and Welding 2 04-09-2005 04:09 PM
351c Turbo headers construction in its infancy duplox Metal Shaping and Welding 28 12-10-2004 02:22 PM
Turbo headers andrewken Eclipse 2000+ 6 10-25-2004 06:13 PM
Twin Turbo Header PostVolvo Off-Topic 2 02-20-2004 01:01 PM
