Hummer wheels on Z-71
Does anyone know if stock hummer wheels and tires will fit on a 2000 Z71 (1/2 ton) with a 3" lift. I think the size of the of the tire is 315/70R17 I know I would need lug adaptors, but other than that I was wondering. This is my first post, so help me out here.
2000 Z-71 3" Straight Pipes "Slobber on These Pipes" |
Re: Hummer wheels on Z-71
Might not need lug adapters if it's an H2......
I would say they would probably fit but don't know for sure, wait for someone else to chime in...
Steve 2004 2WD 5.3 Xcab StepSide |
Re: Re: Hummer wheels on Z-71
I was wondering about H2, I forgot to mention that. I'm pretty sure they have 8 lugs like the 3/4 tons where the 1/2 tons only have 6 lugs.
I think they only have 6 lugs. IF they do, you won't need any kind of adapter. As for the tires fitting, I think that with a 3" lift, they would, it mightbe tight, but worth trying. THe wheels might have a little different backspacing, so check to make sure they dont hit the A-arms or anything.
1998 ECSB Z71
Whelen LED's Kenwood 2-way "BIG 3" 2500+ watt audio ![]() |
They are 8 lug wheels... same as 3/4 ton trucks. More work than it is worth. You can buy aftermarket wheels cheaper than the cost of the hummer wheels and adapters.
How about using some Escalade wheels? I know their 6 lug.
1998 ECSB Z71
Good Idea....I just started looking at them before I came to the site for the day. I guess great minds think alike. I'm looking for something factory because you can get new car take-offs (rims and tires) for about the same price as you can get just tires.
I think the Escalade wheels would look pretty good. Its hard to find some chrome stock wheels!!
1998 ECSB Z71
I was looking at the hummer wheel/tire combo as well. The specs are as follows,
TIRE SIZE: LT315/70R17D TIRE DIAMETER (HEIGHT): 35" in ROAD SURFACE TREAD WIDTH: 10.25 inch SIDEWALL DESIGN: Outlined Raised Black Letters LOAD RANGE: D PLY RATING: 8 PLY Wheel Size, 17 x 8.5 8 Lug on 6.5" Bolt Pattern Back Spacing, 5-9/16" Wheel Offset, +20mm (Positive Offset) Hub-Hole Diameter, Aprox 4-5/8" I just bought a 93 2500 w/ 454 that I would like to put these wheels and tire on. How much lift would I need to make these work?
"So many projects...So little time" |
I would try at least 4". You can maybe go with a body lift, althugh I don't really like body lifts, they are cheaper (say around $100 give or take some). I owuld use a suspension lift myself. A 4" suspension lift costs roughly $1200 depending on what brand you buy.
1998 ECSB Z71
Don't know about H2 but regular Mil-Specs look awesome on Z-71s. They will fit, but will require light trimming of the fender well.
do you know where there are any pics of these rims on a truck? i'm wanting to do something original, and i've never seen those on anything
Follow link to my gallery. I have a pic of them on a '94 Z71.
owning an H2 just to let you know they rub on the torsion bar on the Hummer. I have some friends that have installed the OEM rims on there trucks with out a problem. Now if you want install them on a Dodge you will have to have them milled a little so the hub will sit flush. her is a link to our Hummer site you will see them on a Dodge. Hope this might help. I figure a Hummer owner would of chimed in on this. Good Luck
http://www.hummercommunity.com/showthread.php?t=694 Dirty H2
Here is a link on wheel adapters to go from 6 lug to 8 lug.
http://www.ezaccessory.com/Wheel_Ada.../6550-8650.htm Dirty H2 |
