Old 04-13-2004, 03:14 PM
Odium Odium is offline
Removed Dash-Won't Start
Yesterday I removed the dash from my '95 LeSabre to install a new aftermarket radio. I tried to start the car once I had the headunit wired in without the dash attached, but it wouldnt start. I assumed it was just an antitheft feature so I finished installing the radio. I put the dash back on and tried starting it again. It wouldn't start with the dash on either. When I try to start The motor will turn on and start to run but then sputter and die. I'm still wondering if it is some kind of antitheft device I accidently tripped. I lost one of the dash screws that goes into the A/C vent hole, would that affect anything? Please offer any advice or help you can!
Old 07-17-2004, 09:38 PM
Oleshka10 Oleshka10 is offline
Re: Removed Dash-Won't Start
You must have cut some wires in the dash accidently, because i also own 95 lesabre and installed the same application, i would check the wiring, and maybe the fuses
Old 09-14-2004, 06:27 PM
rcobourn rcobourn is offline
Send a message via ICQ to rcobourn Send a message via AIM to rcobourn Send a message via MSN to rcobourn Send a message via Yahoo to rcobourn
Can anyone recommend after market radios for '95 Le Sabre? So far I've heard the depth is insufficient (this from Crutchfield), but you've obviously found something. Minimum requirement is CD and front panel aux inputs, would like cassette, MP3, and even DVD-Audio if possible. Also looking to upgrade the speakers.
Old 09-16-2004, 01:08 PM
sallisonbrown sallisonbrown is offline
Rcobourn,
Go back and read the posts in the below, "Not a DIN and a half, and NOT a Double DIN"
A lot of good info is offered there on what you are looking for.
1996 Jeep Cherokee Won't Start mocojpo2003 Cherokee 16 09-14-2011 03:39 PM
1994 Intrepid dash lights not working, won't start abrisendine Intrepid 0 08-08-2010 01:20 PM
'00 COUGAR removing dash gw84 Cougar 0 04-28-2009 08:08 AM
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 03:20 PM
HELP! no CEL on dash, won't start!! Solomon7 Cherokee 10 07-18-2007 12:36 AM
