Go Back   Automotive Forums Car Chat > Honda > Exterior | bodykits | Lighting
Exterior | bodykits | Lighting When your ready to showoff that 'H' ride, here's your forum!
Old 04-13-2004, 02:24 PM
dan18732 dan18732 is offline
Send a message via AIM to dan18732
projector w/ halo ring installation.. need help
I had just purchased sonar generation 3 projector headlights with halo rings. It came with instructions, but they were not complete. does anyone know where to wire the 2 wires for the halo ring to?
Old 04-14-2004, 11:31 AM
Froggysquasher Froggysquasher is offline
Send a message via AIM to Froggysquasher
Re: projector w/ halo ring installation.. need help
to the 2 wires for the parking lights...
Old 04-14-2004, 11:46 AM
Tranzlogic Tranzlogic is offline
Send a message via AIM to Tranzlogic
You can wire the Halo Rings to any lighting acc...Of course there gonna ground, but as far as your 12v wires, I would splice into your park lamps as foggy stated. Just make sure you dont wire into the turn signal, which im sure you know the diff. If you wire it into the signal then of course they will only illuminate when the signal is on. make sure when you wire it up to your running lights that you make a good splice and use a good closed connecter to make the intersection and wrap them tightly in electrical tape around the connection and up and down teh wires about an inch and a half to make sure no moisture ever gets on the connected area.
Old 04-14-2004, 09:50 PM
Re: Re: projector w/ halo ring installation.. need help
Hey,
Thanks alot, I was right after all, but i wanted to atleast check with someone else that may have done it already. i'd rather do it right the first time. Thanks again.
Old 04-15-2004, 11:10 AM
no problom bro
Need help with tachometer install! AHHKILLA Eclipse 2000+ 0 05-03-2009 10:04 PM
2002 civic cai install, need help please itsmeek '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 5 04-04-2003 09:45 AM
Clutch Installation *need help* SmokinJs420 '88 - '91 Civic | CRX | Wagon | Shuttlee 4 09-24-2002 01:58 PM
Projector Halo Rings not Bright? Civ_Jimbo Exterior | bodykits | Lighting 7 06-21-2002 08:09 PM
P11 Spoiler on a P10 install need help str8maxn Cosmetics 5 12-21-2001 09:53 AM
