Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 04-13-2004, 02:03 PM
jhuanger jhuanger is offline
Car sometimes stalls when driving,help?
Hey hopefully you guys can help,
I have 1997 honda prelude 5spd that soemtimes stalls while I'm driving it (happens every so often). Oftentimes I just restart the car by putting it down to a lower gear or by simply turning the igntition again. It has some modifications (intake, exhaust) and I'm thinking it is a result of the poor flow from my exhaust or maybe a damaged cat? I've also heard that there was a recall on 1997-2000 honda models regarding a faulty ignition switch? Either way, I don't know too much and need some help. The car doesn't drive as a quick as it used to (no back pressure and feels slow off the line) Any help? Is the problem in my exhuast or elsewhere? Thanks in advance
Guy with a Lude
Old 04-13-2004, 05:20 PM
Prelewd's Avatar
Prelewd Prelewd is offline
Send a message via AIM to Prelewd
Re: Car sometimes stalls when driving,help?
What diameter exhaust piping are you using? It probably doesn't explain the stalling, but it might explain your lack of power..
Soon..
Cars:
1990 Nissan 300zx Twin Turbo
1992 Honda Prelude Si 4WS H22a Swap - For Sale
1965 Chevrolet 1/2 Ton - 500ci Cadillac Cometh
1970 Datsun 240z - For Sale
1972 Datsun 240z - For Sale
1977 Datsun 280z - For Sale
1991 Infiniti Q45 - Engine Donor to 240z - Parting out the Rest
Sold Cars:
1976 Jaguar XJ-S - Rear end Donor to Chev Pickup
1971 Datsun 240z
1984 Civic 1500 Hatch
Old 04-14-2004, 01:42 PM
88 ROCKET 88 ROCKET is offline
On my 88 lude the thing would stall alot when it got hot. the high speed idle valve on the back of the throttle body plume was completely plugged with sludge. there is a bowl on the bottom of it where the coolant runs through (thermal valve)... I took the valve off the throttle body and took the bowl off the bottom of the valve and cleaned it out. BE CAREFUL AND MAKE SURE THE ENGINE IS COLD OR YOU WILL GET SPRAYED WITH HOT COOLANT. Then I sprayed the inside of the valve with carb. cleaner and followed up with some WD-40 after it dried... works like new. DON'T adjust the diaphram valve inside... it it factory set.
fuel smell in car and stalls sometimes? HELP mark4674 Taurus | Taurus Wagon 0 12-19-2009 07:08 PM
car stalls when turning left persondude44 Engineering/ Technical 5 04-16-2009 08:18 AM
92 Saturn SL2 sometimes stalls when I do a quick reverse 92saturngrl SC/SL/SW 3 07-27-2008 05:18 PM
Car stalls when driving jmbrogan41 Aurora 1 01-11-2005 06:47 PM
Car stalled when driving on freeway banzai75x Accord/TSX/Accord Hybrid 7 06-16-2004 05:40 PM
