Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 04-13-2004, 10:51 AM
soldiervet soldiervet is offline
Unhappy 2001 Jimmy SLT humming noise front end....
I just got a 2001 Jimmy SLT and just notice a humming noise/slight vibration on left side of floor, while I'm driving and turn the steering wheel 10-15 degree to the right.... No pulling whatsoever
Could it be left front bearing, or the power steering??
Old 04-13-2004, 12:27 PM
scnvsleep scnvsleep is offline
Re: 2001 Jimmy SLT humming noise front end....
Check your power sterring fluid first. Thats easiest.
Might wanna pull your wheel and repack the bearings if its not PS fluid...
Old 04-17-2004, 02:12 PM
GMCTech GMCTech is offline
If it get louder as you turn one diredtion while driving and quieter in the other direction, it is a wheel bearing.
The wheel bearing / hub assembly is a one piece unit, and unfortunately is not too cheap.
I would suggest that you replace it with ACDelco OEM parts. Only because I have yet to see one of the new design hubs go bad, and have seen almost every aftermarket cheap-o hub fail within 2 years of replacement.
Hope this helps.
Old 03-21-2005, 02:52 PM
rledwards rledwards is offline
I too have a 2001 Jimmy, 4-wheel drive. The left front wheel bearing/hub failed at 43,000 miles and now the right one is noisy at 48,000 miles. Is this common on a '01 4-wheel drive Jimmy?
Old 03-22-2005, 06:44 AM
tomj2 tomj2 is offline
Re: Re: 2001 Jimmy SLT humming noise front end....
Both mine went at about 50,000 miles.
Creaking Noise At Front-End el ratfink Pacifica 2 12-05-2009 11:57 AM
Front end noise Bob Moore Dakota 5 07-25-2009 04:40 PM
94 Civic with constant high pitch humming in front end.... lizshouse88 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 07-19-2009 05:49 PM
maoning/humming noise front end 01 ranger bruz Ranger | Courier 1 02-17-2009 05:00 AM
2001 Jimmy clunk/rattle in front end LWESTLAKE Jimmy 8 10-23-2004 02:55 PM
