Old 04-12-2004, 11:29 PM
swamprat swamprat is offline
Engine is overheating
For all of you that have not been able to figure out why your engine is over heating here is all the possible reasons I could find, check those that apply.
Hope this helps.
1 Inspect ANTIFREEZE NEEDED Coolant level low or flow is restricted.
2 Inspect BELT Incorrectly routed, adjusted, tensioned, missing, or worn water pump belt(s).
3 Inspect HOSE Ruptured, cracked or leaking radiator hose.
4 Inspect RADIATOR CAP Worn or damaged radiator cap
5 Inspect THERMOSTAT Thermostat stuck closed
6 Inspect FAN BLADE Broken, missing, or defective fan blade(s).
8 Inspect WATER PUMP Damaged, worn or leaking water pump.
10 Inspect COOLING FAN CONTROL Faulty cooling fan control or circuit.
11 Inspect COOLING FAN SWITCH - RADIATOR Faulty radiator cooling fan switch or circuit.
12 Inspect ENGINE TEMPERATURE SENSOR Faulty engine temperature sensor or circuit.
13 Inspect TEMPERATURE SWITCH Damaged or faulty temperature switch or temperature switch circuit.
14 Inspect FAN CLUTCH Worn, loose or faulty fan clutch.
15 Inspect PORTED VACUUM SWITCH Damaged, leaking, or faulty ported vacuum switch.
16 Inspect RADIATOR Obstructed radiator core or radiator cooling fins.
Old 04-12-2004, 11:30 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: Engine is overheating
thats another big list...
Old 04-13-2004, 02:37 AM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
change your name to haynes!
Overheating AFTER engine stops... wkumale Cherokee 3 07-03-2010 09:01 PM
Engine overheating and temp inconsistency bobiosports Camaro Discussions 1 10-21-2003 10:44 PM
engine overheated Tominos Engineering/ Technical 3 08-21-2002 08:09 PM
