View Poll Results: Am I ok with what I'm doing?
No 0 0%
Yes 0 0%
I Should change somethings 0 0%
Sounds about right 2 100.00%
Voters: 2. You may not vote on this poll
Old 04-12-2004, 10:18 PM
GreekPower's Avatar
GreekPower GreekPower is offline
Send a message via AIM to GreekPower Send a message via Yahoo to GreekPower
Question Is this the best basic first couple of mods?
Ok thanks to help at this forum I'm wondering if this should be the first mods I should get/do when I purchase my VR-4.
1.ATR Downpipe with test pipe
2.4 1/2 intake adaptor from lighting motorsports with 8" Powerstack Filter
3.MSD 10.3mm Spark Plug Wires with BOSCH Platinum 4 plugs
4.Turbo XS RFLTurboXS BOV-Type H-RFL
5.Greddy Profec B or BLITZ SBD-ID (which is better?)
Basically thats what im thinking my first mods will be besides the normal Sparco seat,remove rear seat,18x8's all around and so on and so forth.If u guys have any recommendations that are better then the ones I have listed please tell me.And explain y its better.
Who says GTO's aint badass?mine is
BIGGIE
Old 04-12-2004, 10:21 PM
GreekPower's Avatar
Re: Is this the best basic first couple of mods?
And this would be for a 1993 3000GT VR-4
BIGGIE
Old 04-12-2004, 11:16 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
your gonna need a super afc or fuel upgrades of some sort to run high boost, so that needs to be included
Old 04-13-2004, 07:31 AM
aznnutty aznnutty is offline
don't get bosch 4, get bosch 2, the bosch 4 are known to misfire sometimes, according to autozone..
Old 04-13-2004, 11:20 AM
Igovert500's Avatar
blue + red light magnet
NGK copper plugs are popular
also ATR downpipe eliminates the main cat, so there would be no reason 2 get the test pipe. If you did, essentially you would have to cut the ATR downpipe shorter and then put the test pipe at the end, its a waste of 40 bucks. if you get the ATR downpipe, you don't need a test pipe.
As youngvr4 said, if you run over 14.5psi boost, you will need fuel pump, larger injectors, and air/fuel controller.
If you are upgrading your blow off valve, get a closed loop, not an open-loop bov. The open loop vents air, that has already been accounted for by the MAS, into the atmosphere. Therefore your car runs rich for 3-4 seconds after shifting or letting off the throttle. Some say this causes a rougher idle/ stalling. I'd recommend the GReddy Type-S.
Both boost controllers are good, either would work fine.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Is this the best Chevelle forum? neat Chevelle 3 09-29-2004 11:49 PM
is this the best thing for a teg? nJIN2nR Integra 7 01-08-2004 09:13 PM
The BEST and first mod to get period. RedRacerCivic '88 - '91 Civic | CRX | Wagon | Shuttlee 8 09-09-2002 01:18 PM
Is this the best handsfree kit for your cellphone!! ragt20 COMPLETELY off-topic 12 01-21-2002 03:51 PM
What the best Japanese Sportcar with mods ?? Speedfreak17 General Discussion 10 10-16-2001 09:02 AM
