Go Back   Automotive Forums Car Chat > Porsche > 924/944/968
Old 04-12-2004, 06:55 PM
klinker klinker is offline
i am having problems with my clutch i think.
When the car is cold the clutch will slip between 2000-4000 RPM. But when the car warms up the slipping will stop and the car will run normal again. What do i do?
Old 04-12-2004, 09:57 PM
83-944 83-944 is offline
The Haynes manual tells you how to see how much clutch you have left.
Most likely though, you have oil on the disk from a leaky flywheel seal. Any oil puddles you didn't mention?!
The manual says that there is a hole in the bellhousing where the clutch slave cylinder hooks up. Measure the rod you see in the hole. if it's
1 1/2 inshes long, you need a new clutch.
83 - Porsche 944 - daily driver
62 - VW Karmann Ghia - never ending restoration project
95 - Ford Mustang - wifes
