Soft Brakes???
When it starts warming up, and I've run my car for a while my brakes start getting soft - they go almost to the floor before they start getting harder. Any ideas what this could be?
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete) www.naytontech.com :: youtube.com/naytontech |
check your brake booster. Mine did the same shit and kept getting worse. Turned out to be my booster. Id look at it asap too because your always going to need to stop.
ZC stuff http://dh-racing.com http://www.thezcr.com/html/zcbook.php http://dmoore.com/crx/zc.htm http://www.jgenginedynamics.com/HOME%20PAGE http://www.theoldone.com/
it could also be a problem with air in the brake lines, they may just need to be bled. i had a guy in my class that had the same problem, but don't just count on the first thing someone tells you. this problem could be alot of different things.
"When angels are forced out of heaven, they become devils." "You think I'm vicious, I'll show you vicious." |
Yea, i agree. Thats another possibility. But to check your booster, heres what you do... Dont start the car, just sit in it and pump the pedal a few times so it gets nice and stiff (dont laugh) when it does get stiff (if it never does its a bad check valve), hold it down and if it gradually sinks or goes to the floor, you may have either a leaky hose, leaky cylinder, or a bad master cylinder. Now, with your foot on the brake, start the car and it should sink a bit. This is to test your brake booster. If it doesnt sink, the booster or check valve is bad.
Re: Soft Brakes???
chronic brake-booster syndrome - CBS!
Re: Soft Brakes???
Well, it's not a leaky hose cause I've had the same brake fluid amount for the last few months -
Re: Soft Brakes???
Master Cylinder??? Before I got the car that happened to my parents after a while and it was the master cylinder, i believe.
***90 Civic EX 4 Door*** ![]() Quote:
Re: Soft Brakes???
I'm going to bleed my brakes tomorrow, but whats really weird about this is that the brakes can be really soft one stop light, and the next they are normal. They keep going back and forth, fine, then soft, then fine - really weird - I'm hoping it's just a bubble or air in the lines. I don't feel like messing with the master cylinder. BTW - how easy is it to remove and/or replace the master cylinder or parts to it???? I've never messed with it.
Its not too hard at all. Pretty much just take the old one off, put the new one in, bleed the lines, and your set. It really does sound like a master cylinder or booster problem to me though. Kinda sounds like the primary or secondary seals are getting too soft which means replacement of the MC.
i have the same problem ever since this guy took out my master cylinder to get out my alt. but anyways...when i stop and SLAM the brakes they work fine but say if i stop and gradually come to a stop i have to usually pump it at least once sometimes more...im pretty sure i need my lines bled but i dunno...the fulid has been the same for a long time too so its not leakin
I have a B18A1 with a T3/T4 turbo charger and MANY extras looking for a fuel management unit and exterior mods. interior mods are just a 5 point harness and racing seat with roll cage and a 3 point for pass with a racing seat. Car will be done by april 20th |
Re: Soft Brakes???
Ya, mine is like that too - if I try and stop really quick and slam on the brakes they are fine, but a gradual stop they slowly go to the floor. We'll see what the bleeding does.
sounds like the master cylinder to me... same thing happened to my wifes accord.
do yourself a favor and buy a rebuilt one and throw it in. i went to Kragen and bought one and it was the same one as the factory one that i pulled out and it was really cheap.... haven't had any problems since.
1993 Civic Coupe EX 1997 Chevy Suburban LT “It's all fun and games - Until someone loses an eye" |
Also, if it turns out to be the MC, dont forget to bench bleed the MC. makes bleeding a lot easier.
FLINT BLACK 1990 CRX SI Appearance Mods: -JDM EF8 CR-X SiR Spoiler -94/95 Integra GS-R rims Performance Mods: -JDM B18C swap -OBD1 conversion -Chipped P28 ECU -Skunk2 Intake Manifold -DC Sports 4-2-1 Header -MSD SCI-L ignition -EXEDY Racing Clutch Interior Mod -'95 Integra GS-R Gauge Cluster Former Motors - RIP: -JDM B16A #1- Blew up due to over-revving -JDM B16A #2 - Hydrolocked Former Cars '89 CRX Si - "The Bumblebee" '94 Integra GS-R![]() '96 Camaro
Re: Soft Brakes???
was just about to mention that, me and my buddy replaced mine in 2 hours mainly cuz the lines to the mc were a bitch to loosen, and cuz the bench bleeding took a lil while to do, its not a hard job to do tho
94 s-10 bagged, body dropped, 22's, suicide coupe doors, fully shaved, and soon a small block 350 2011 Silverado... Stock Daily driver
Re: Soft Brakes???
I bled my bakes some today - and I noticed something - what color is brake fluid supposed to be - the stuff that came out was like this greenish color (darker too) - the new stuff I bought to put in is clear? Is that normal?
