Old 04-12-2004, 06:07 PM
prevch prevch is offline
Need help running wires for a neon underbody kit install
I need some major help. I am about to install a neon underbody kit on my car but I cannot figure out how to run the wires and it is driving me insane. I am trying to hook up the wires to the battery and then run them into the car to hook up the switch and then from the switch to the bottom of the car to the transformer. HOw do I get the wires inside the car from the battery? I mean the firewall is in the way is there any easy place to run the wires in? Then once I get them in what is a good way to run the wires underneath the car? Any help would be appreciated I have been working on this forever and it is driving me nuts. Thanks!
Old 04-12-2004, 10:15 PM
Nephest's Avatar
Nephest Nephest is offline
Send a message via MSN to Nephest
Have you ever ran an AMP cable? You can run it from the battery along the fender, and through the door crack, looks bad but easy. Or you could run it THROUGH the fender like alot of the cables are, but in order to do that, you would have to run it across the engine bay. I had to remove my fender when my hood latch cable broke, that is when i ran mine. It goes right through your firewall on your driver side. And about runnin it under neith, i dunno.
Live for the speed, die for the rush.
Live for the rush, die from the speed.
Old 04-12-2004, 10:36 PM
ok I will check it out I just could not find a spot in the firewall where the was a spot to put wires through but I will looke there. I wanted to run the wires through the firewall so maybe they would come up where the stereo is but I will see what I can do. Thanks for your help.
