Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 01-10-2002, 11:39 PM
Army Sgt Army Sgt is offline
Aftermarket Lock in/out Front hubs
Less wear and tear ???????
Better gas mileage ???????
:xelicon:
" This We'll Defend "
Old 01-11-2002, 01:40 AM
rrdstarr's Avatar
rrdstarr rrdstarr is offline
Yes
Yes
Get Warn hubs from EOE!
We don't give a damn how loud your stereo is!
Did you read your owners manual yet?
V.P. of PNWX
Old 01-11-2002, 02:45 AM
xoc's Avatar
xoc xoc is offline
No.
No.
When the front is unlocked, nothing is turning, regardless of what type of hub is used.
Regards,
Ian
Old 01-11-2002, 09:08 AM
Thankyou !!
Thankyou !!
If you "GO ARMY " go into Aviation.
Old 01-11-2002, 09:23 AM
cmxterra cmxterra is offline
Pizza!
Pizza!
These things float... right??
Old 01-11-2002, 09:27 AM
Chris_McCracken Chris_McCracken is offline
what about stronger?
I think the main reason people switch to manual hubs (I could be wrong, though) is that that they are significantly stronger than the Nissan auto hubs. At GOX, I saw several people blow the auto hubs (the only one I remember by name was Ivan). As far as I know, noone has blown an aftermarket hub (except Matt Peckham and that Milemarker hub, but there were "installation issues"). I personally don't like the idea of having to stop and get out to engage 4WD. I'd rather carry a spare auto hub (its not like they're difficult to replace).
Old 01-11-2002, 09:57 AM
rhombus's Avatar
rhombus rhombus is offline
The other reason is explained on the http://www.maxc.org site.
Here is the snip from the site:
Credits going to Mr. T & Synchro
<snip>
Auto hubs VS. Manual hubs
Why ditch the stock auto hubs in favor of manual hubs?
Automatic hubs actually disengage briefly when the vehicle is in 4WD and you switch directions, i.e. frontwards to backwards, backwards to frontwards. The front wheels have to roll in the new direction a short distance before the hubs will re-engage (about one foot). This means that you're in 2WD until the hubs hook up again. When you get stuck while in 4WD, if you try to rock the vehicle frontwards and backwards to free it, you end up in 2WD for much of the experience, which means you might remain stuck because you don't really have 4WD to pull you out. When the hubs do re-engage, and if the back wheels are being turned by the engine faster than the fronts happen to be rolling, you get a big CLUNK as the hubs kick in again. That's hard on the hubs and front driveline. Manual hubs do not do this, they are either LOCKED or UNLOCKED.
<end snip>
rhombus
SOXC Member
http://www.soxc.org
Old 01-11-2002, 04:38 PM
VaderX VaderX is offline
Send a message via AIM to VaderX
You also might consider additional problems broken hubs can cause. Mine were blown and one would not disengage. What ended up happening is that both wheel bearings in the front were ruined as well as one of the knuckles. I am not positive that the broken hubs caused this but since they were the only things malfunctioning I can't imagine it was anything else. I switched to manuals and while it is a pain to get out it is definitely a comfort to know they won't blow as easily.
Old 01-11-2002, 04:42 PM
Kerensky97's Avatar
Kerensky97 Kerensky97 is offline
I've had that problem on snow, I backed up and tried to get going again but couldn't get any forward movement to re-engage the hubs.
But its not that hard to just back up more than usual so you can get an extra foot to re-engage the hubs when you move forward again.
In the automatic the tranny doesn't shift quickly enough to for you to rock very well anyway.
For now its nice to be able to not have to get out and switch the hubs.
-Dustin
2000 Nissan Xterra XE, Sport Package, 4X4, Automatic.
And yes its better than yours.
front bearing - new or junkyard replacement? gijmcd Sonata 5 02-15-2010 08:15 PM
'95 noise stops when in put in 4 high HUB??? lizzye71 F Series 3 12-23-2009 07:51 AM
'95 noise stops when in put in 4 high HUB??? lizzye71 F Series 0 12-21-2009 08:16 PM
4WD Hub won't lock in....! DOCTORBILL Tracker 0 12-04-2007 02:38 PM
Front Hubs Not Locking UP frafreg Sidekick 5 12-21-2005 10:24 AM
