Old 04-12-2004, 02:56 PM
ViperJ's Avatar
ViperJ ViperJ is offline
Send a message via MSN to ViperJ
Amp Wire Under Car
How bad is it to run an amp power wire under your car. I am wondering because there is no where else to run it through my firewall.
White 07 STI, Bone stock for now
Old 04-12-2004, 03:11 PM
dbiggss dbiggss is offline
what gauge wire are you running?
Old 04-12-2004, 03:31 PM
ViperJ's Avatar
Re: Amp Wire Under Car
8 Gauge
Old 04-12-2004, 04:00 PM
MStout's Avatar
MStout MStout is offline
Why not...just find a nice spot for it that can use wire ties and things like that. My friend said he ran it along the gas line and then up through the drain on his spare tire compartment...try that.
Old 04-12-2004, 04:21 PM
well, it would make your power wire at a much higher risk to damage, plus it might even be more difficult - i wouldnt do it. two other options are: 1.(the ghetto way) - run it through the door jam and then under all the moldings in your car - a lot of people will advise against this, however i have seen it done many times with wires as thick as 8 ga with no problems. option 2: the right way - borrow a drill and just make a new hole in the firewall for it> its not that bad.
Old 04-12-2004, 04:47 PM
baller_d935 baller_d935 is offline
I would'nt recommend you run it under the car so it does'nt weather away. and don't run anywhere near the gas line just to be safe.
Old 04-12-2004, 06:13 PM
aznxthuggie's Avatar
aznxthuggie aznxthuggie is offline
u can drill a hole thru ur firewall, just not a big hole, and run it on the side of ur car, i ran mines along the footwell, or however u call it, along the interior of my car
Old 04-12-2004, 07:38 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Re: Amp Wire Under Car
Wow, run a high current electrical cable next to a highly flammable gas line, sounds like the setup of champions. Wouldn't want to be in that car in an accident
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 04-14-2004, 09:11 PM
MStout's Avatar
Yea...doesnt sound like a good idea. He said he did that though and I never was quite sure to believe him or not. But if there were any place else to zip tie it that would be an ok idea...but dumb since it IS easy to run it through your car...was for me anyway.
Old 04-16-2004, 09:27 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
a LOT of show cars do that .... they run it in a metal conduit
Old 04-16-2004, 10:10 PM
ViperJ's Avatar
Thanks for all the help guys. I decided to run it through the inside to be safe.
