Go Back   Automotive Forums Car Chat > Honda > Integra
Old 04-12-2004, 02:06 PM
IntegraB16 IntegraB16 is offline
Too Much Fuel!!
This weekend I had to replace my clutch. I have done this 3 times now. This time was different. I did everything like i usually do but when i put everything back together and start the car it is having a hard time running and it is letting out some black smoke from burning too much gas. So something happened and now my car runs WAAYYY rich. What could have caused this? Is there anyway that i could lean out the gas without having to buy a fuel pressure regulator?
Old 04-12-2004, 03:05 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: Too Much Fuel!!
Have you driven it down the road yet? Does it rev past 3,500 rpm? It sounds like you are in limp mode. Try checking all the sensors and wires. You need to fix the cause of the problem not change the problem with another part.
Old 04-12-2004, 09:51 PM
integrasedan integrasedan is offline
if the problem is too rich, could be weak ignition system, checkout the coil, sparkplug wires, and spark plugs. check for dirty air filter and proper spark plug gap.
also check the oxygen sensor.
Old 04-13-2004, 12:14 AM
integralover's Avatar
integralover integralover is offline
this sounds exactly like me trying to fix my car and causing another problem.
93 teg LS
B20B
ACT Performance Flywheel
AEM CAI
DC Sports Stainless Steel Header
G4 High Flow Cat
GReddy MX Cat Back Exhaust
Skunk2 Racing Chip
Lots of interior goodies
Old 04-13-2004, 10:43 AM
Re: Too Much Fuel!!
I was thinking it could be my O2 sensor. Does anyone know how much thoes things cost? I have an MDS SCI ignition, a blaster 2 coil, and bosch platnum 4 plugs. It seems to be burning it. There is just way to much gas. The fumes are soo strong they burn my eyes. If it isn't my O2 sensor what else could it be??
Old 04-13-2004, 02:15 PM
whtteg's Avatar
Re: Re: Too Much Fuel!!
Have you followed my advice and checked all the wire connections. Especially the ones you had to take loose to take the tranny out? 9 times out of 10 the new problem is 100% realated to the work that has just been done to the car. If you want your car fixed then take my advice!
Old 04-13-2004, 06:11 PM
that's some pretty strong ignition, it should burn most of the mixture. just follow Whtteg said, Check sure you didn't forget to connect something.
Old 04-13-2004, 06:25 PM
Re: Too Much Fuel!!
Yeah I have been checking the wires over and over again for the last three days. I also have been using a flashlight and looking behind the engine by the firewall for anything i could have disconnected and not noticed.
Old 04-13-2004, 06:42 PM
i'm sorry that's about all i can help. good luck
89 t-bird poor idle and uses too much fuel joneser02 Thunderbird 2 12-11-2004 05:22 PM
runs terrible, floods, too much fuel, suggestions? crank182 Blazer 3 07-05-2004 05:35 PM
CARB GUYS-305 Smoking-Too Much Fuel? sdnicker Camaro Discussions 1 12-24-2003 09:08 AM
too much fuel? Quetzolcotl Engineering/ Technical 1 01-07-2002 09:55 PM
Too much fuel system cleaner sciguyjim Engineering/ Technical 2 09-11-2001 09:31 AM
