Old 04-12-2004, 01:32 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
Panel lines, how to make them fresh?
Say you're adding a body panel. Or a door. Or a hatch in, say, a scratchbuilt fastback. How would you scribe the panel lines? I tried freehand but they're all wavy. I can't use a straight edge because the edges aren't straight. How is it done? I've seen piles of well cut panel lines custom made in models all over the place. Especially on slosnipe's immaculate Civic sedan. What's the secret? Templets? French curves? Magic? I'd like to know so I can fill the lines and give it another, better, go.
Old 04-12-2004, 01:41 PM
gasman03's Avatar
gasman03 gasman03 is offline
take some thin plastic sheet, cut it in a straight line or a line to match the new door, tape it down where you need it, and then run a very sharp Xacto along the edge of the plastic, it should allow to have a very straight line,
Old 04-12-2004, 01:51 PM
Vric's Avatar
Vric Vric is offline
Re: Panel lines, how to make them fresh?
I have a flat Xacto about 2cm wide..
it might be wavy, but only every 2cm
Old 04-12-2004, 02:34 PM
Veyron's Avatar
Veyron Veyron is offline
There are scribing templates that military/aircraft modelers use because many of those kits have raised panel lines instead of engraved.
They have templates for curves, 90 degree corners, straight lines and rounds.
Rims..how do i to make them look like new? spacey Tribute 1 05-14-2006 05:46 PM
1/20 hood pins: who makes them, who has them? racer917 Car Modeling 5 04-28-2006 08:57 PM
How to get Compound out of Panel Lines?? RX7FD Car Modeling 16 02-04-2003 05:33 PM
