Old 04-12-2004, 01:05 AM
Dorkula Dorkula is offline
Changing oil
Since I do not have the owners manual to my 92 geo metro auto trans 4 door, I was wondering if anybody knew how much oil to put into the car?
Thanks for the help.
- Anthony
Old 04-12-2004, 03:13 AM
barteldt barteldt is offline
Send a message via AIM to barteldt Send a message via Yahoo to barteldt
Re: Changing oil
3-4 quarts try checking the dipstick after the 3rd quart
Old 04-12-2004, 08:31 AM
Re: Changing oil
Thanks, I apprectiate the help :-D
Old 04-12-2004, 04:55 PM
geozukigti geozukigti is offline
Try not to use anything thinner than 10w30. 5w30 just doesn't cut it for any of the 3 and 4 cyl metro motors. It passes right by the valve seals, and will cause valve ticking. Especially synthetic. I've had a few friends kill their GTi and 3cyl engines running synthetic.
Old 04-20-2004, 08:35 AM
lucky03602 lucky03602 is offline
Send a message via MSN to lucky03602 Send a message via Yahoo to lucky03602
Re: Changing oil
the metros normally take 3.5 qts.
Old 04-21-2004, 01:25 AM
insomica insomica is offline
Send a message via AIM to insomica Send a message via Yahoo to insomica
Re: Changing oil
Does this apply to '94 trackers? Because I wanted to use synthetic keep the engine in running good.
Old 04-21-2004, 12:38 PM
G10a, G13a, G13b is what I have experience with. If your tracker has one of those motors, I would shy away from the synthetic.
Old 04-21-2004, 10:04 PM
Re: Changing oil
WHere would I look. When I got my 94 geo tracker it did not come with a manual. I guess thats what you get when you pay $500 for a traker.
EDIT-> My Engine is a 1.6L I-4 MPI
Old 04-22-2004, 03:34 PM
Not much experience with the 1.6's. They are similar to the 1.3's tho. most internals, and the engine heads are interchangeable. If it has over 100,000 miles on it, I wouldn't start putting synthetic in it anyways. 75,000 miles is a good cap for that. Bearings start to wear out, and tolerances get bigger. You might notice a signifigant loss in oil pressure at idle with synthetic.
Old 04-22-2004, 03:37 PM
Re: Changing oil
Thanks for the info.
It has 111,000 miles on it. I will just use what ever Firestone puts in it.
Old 04-22-2004, 08:38 PM
Re: Changing oil
another thing with full synthetic oil that no one talks about is that the reason its not recomended for higher milage vehicles is tha fact that it actually decreses the life span of your motor seals, it basically eats tha gaskets away. if you run full synthetic motor oil from day one your fine, but if your seals are a little worn then youll notice that youll be burning thru alot more oil.
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
