Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 04-11-2004, 10:47 PM
JapPrecision JapPrecision is offline
Banned
Question Width question...calling all tire experts!
I have an 89 CRX SI with the stock 14' si wheels. Im trying to keep the car as sleeper as possible. I do not like attention from Cops or theives...and I'm not into huge wheels --raising the height of the car or slowing it down. The stock tires on the SI wheels are 185/60/14. I am also on a college budget right now (need to leave $ for books/beer/ramen) I was wondering if someone could tell me how wide of a tire I can run without any trouble, and if so, will they "bubble" out of the rim and look shitty/and/or ride shitty due to the slim wheel size. Any help or suggestions will be much appreciated.
Old 04-12-2004, 11:54 AM
tran_nsx's Avatar
tran_nsx tran_nsx is offline
Re: Width question...calling all tire experts!
go to tirerack.com, type in your car and they should tell u the widest your tires can go. if your looking to get better traction, wider tires would nessecarily do the job, it might help a small amount, but thats it. the key to getting traction is from the compound of which the tire was made of.
Old 04-12-2004, 05:11 PM
Banned
I guess my real question was --does it make sense to run wider tires than that of the size of the wheel (and will this result in a setup where the tires are actually wider than the wheel and bulge out, possibly creating a worse scenario((in terms of looks and performance)) when compared to the recommended width).
By the way tran-nsx, -- sick Teg--good taste. -- i just bought & sold a 91 GS with a shitload of miles and made bank off it--I almost didnt want to sell it!
Old 04-12-2004, 05:49 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
I would suggest not to exceed the width of the rim by more than 1 series ie: 195/60/14 is the widest I would go, or 195/50/14 would be better because it would be about the same height and a bit wider.
Old 04-15-2004, 11:46 AM
tchach11 tchach11 is offline
guy! i think you should put huge tiya's on your cah! like 255/40/14's. it would be sick guy! then you could do buhn outs! i like ramen too!
Old 04-15-2004, 01:27 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: Re: Width question...calling all tire experts!
a 195/55/14 would be about the same height. But yah, 195 is the widest you can go. Falken Azenis come in 195/60/14. Had those on my 4th gen and they were great. H-rated tires unlike the other ones which are V-rated I believe, but still one of the best tires I have driven on.
BTW: tire size calculator: http://www.miata.net/garage/tirecalc.html
Empty Pockets Racing Member #1
Old 04-16-2004, 08:56 AM
THEOLDMAN THEOLDMAN is offline
The most important measurement is the width of the rim, it will determine how wide of a tire you can put on it. Tires are designed with a specified range of rim widths, in order for them to flex properly the rim needs to be within the tires design parameters.
Driving the Milano Red RSXTypeS or the White '89 325i listening to Blues & Jazz
Old 04-18-2004, 10:09 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
guh-guh-guh-gangsta
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Calling All Trans Experts... I need help bad! JakeDrummer Integra 8 05-22-2004 08:02 AM
calling all jetta experts.. quaddriver Jetta/Vento/Bora 5 04-18-2004 01:17 PM
Calling All Fiero Experts!!!! MNWILD Fiero 3 11-21-2003 11:09 AM
Calling all ZC experts/ anyone who can help EFsleeper Engineering/ Technical 1 08-06-2002 12:57 PM
Calling all ZC experts EFsleeper '88 - '91 Civic | CRX | Wagon | Shuttlee 5 08-05-2002 05:16 PM
