Old 04-11-2004, 10:20 PM
paulomartin paulomartin is offline
Unhappy Engine misfires on plug #6
The code reader reports P0306, misfire on plug number 6. I have replaced the plug wires and plugs and I have check the coil. All is working and the plug wire shoots a strong spark. The injectors are all clicking but the code reader still shows 6 continues to misfire and the engine is missing while running. Is the problem a bad injector? Help!
Old 10-10-2004, 10:21 PM
buickmastermind's Avatar
buickmastermind buickmastermind is offline
Re: Engine misfires on plug #6
Change the connector with that of a different injector (if you can. It's easy enough). If it continues to misfire, bad injector. If a different one now misfires, then you got a bad connector.
Old 11-08-2004, 08:04 PM
stank23 stank23 is offline
Send a message via AIM to stank23
be sure to use ac delco spark plugs i didnt and i had 3 cylinders misfiring.replaced them and all was good
Old 11-11-2004, 04:56 PM
chat22 chat22 is offline
Could you use this method for a Pontiac Grand Prix GT?
Old 11-11-2004, 05:01 PM
Could you use this method for a 2000 Pontiac Grand Prix GT?
Old 11-11-2004, 06:14 PM
What problem are you having with the GP? I think it may be a little difficult to get at your injectors, but if you swap the connectors between two injectors, you should be able to hear if it is clicking or not. Click=good injector.
1986 LeSabre Limited L67 sleeper
Fully ported & polished, shift kit, CAI, F41 polyurethane suspension, headers & 3" exhuast,
98 Dakota single cylinder misfire following overheating 98dak0ta Dakota 2 01-28-2011 02:02 PM
Durango cylinder 1 misfire sprecks Durango 5 06-28-2009 01:00 PM
'99 Yukon misfires and won't start ZippyCT Yukon 10 05-29-2009 08:46 PM
P0305 Cylinder 5 Misfire wmuwop Explorer | Explorer Sport Trac 3 03-31-2009 06:40 AM
Misfire, plugs 2,4,6 w/carbon 1,3,5 fine Lefort Millenia/Xedos 9 15 11-10-2004 02:40 PM
