Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 04-11-2004, 04:28 PM
ebony ebony is offline
Angry Help!!! First Car And Its F@#ked!
Please Help!!! I just bought a 1989 Honda Prelude. It ran fine for the first hour then started idleing funny. Like coughing n splutterin kind of shit. Well by the time I managed to maneouver it home it had been stalling at every red light and nearly caused a major accident. I dont know what to do, its a public holiday today, and i dont want to ramdomly go to a mechanic as a clueless girl and get ripped off. Im so broke...
PLEASE HELP
WILLING TO BE CAR TRAINED!
_________________
this is my first car... i know nothing about cars... i need help *nods*
Old 04-11-2004, 05:39 PM
km23honda's Avatar
km23honda km23honda is offline
Send a message via AIM to km23honda Send a message via MSN to km23honda Send a message via Yahoo to km23honda
Re: Help! First Car And Its F@#ked!
Is that all it did. Maybe explain it a little more if you could. A lot of people on AF is really good at things as long as there is enough detail behind it.
1992 Honda Prelude SI
Old 04-11-2004, 06:00 PM
its hard to explain cause i dont know terminology...
um, it sounds sound smooth when driving, it sounds disjointed u know? like spluttering but not too bad. on the freeway its fine. the accelerator is touchy ie. if i accidentally put my foot down too hard it just revs really loudly really quickly but takes like awhile to actually pick up any speed, by then ive backed off.
ok the main issue - as im coming to a stop the car gets shaky and chokes up. if i accelerate again its fine but if i have to come to a complete stop it will shudder abit then just die. i have to get out of drive (its auto) turn the car back on while gently accelerating so it catches and throw it straight into drive without braking first then changing gears, doing it sounds terrible. i just had to get it home though. its now sitn outside in the cold
if theres anything else u wanna know try be specific cause... well yeah, from my description u can see why! i dont know what im talking about!!!
please help
Old 04-11-2004, 08:19 PM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
Is your car carbuerated? If you don't know, take a picture of the engine bay and I can tell you. Our 87 Accord does the same thing. It died at every single stoplight if you stop giving it gas. If your car is carbuerated, then you've got an easy fix ahead of you. Fixing rough idle on a fuel injected model is a bitch, I can tell you right away.
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
Old 04-12-2004, 12:55 AM
Prelewd's Avatar
Prelewd Prelewd is offline
Send a message via AIM to Prelewd
Check your spark plugs too, before you do anything.
Soon..
Cars:
1990 Nissan 300zx Twin Turbo
1992 Honda Prelude Si 4WS H22a Swap - For Sale
1965 Chevrolet 1/2 Ton - 500ci Cadillac Cometh
1970 Datsun 240z - For Sale
1972 Datsun 240z - For Sale
1977 Datsun 280z - For Sale
1991 Infiniti Q45 - Engine Donor to 240z - Parting out the Rest
Sold Cars:
1976 Jaguar XJ-S - Rear end Donor to Chev Pickup
1971 Datsun 240z
1984 Civic 1500 Hatch
Old 04-12-2004, 11:47 AM
its dual-carb i was told. it was worse today. it wouldnt reverse and was blowing alot of smoke out of the back. i checked the spark plugs they looked new.
it seems to do it in the hot daytime weather cause it wasnt doing it when i drove it home the cold night i bought it.
thankyou so much everyone!!
Old 04-13-2004, 11:21 AM
AcesHigh's Avatar
Prelude Guy
Hmm... I could give you the throttle bolt fix, but I don't think that would do you any good. Bring it into a mechanic, they'll tell you what's up. Most mechanics are pretty straightforward people.
Do come back and update us when you find your problem.
Old 04-13-2004, 04:49 PM
Prelewd's Avatar
Re: Re: Help! First Car And Its F@#ked!
Where I come from, there is a place that only does hondas and acuras. If you could find someplace like that around your area, you'd probably be better off. Just don't let them tell you that you need a million differnt things for your car.
Soon..
Cars:
Sold Cars:
1971 Datsun 240z
Old 04-13-2004, 08:07 PM
spedwezl's Avatar
spedwezl spedwezl is offline
Send a message via AIM to spedwezl
same thing used to happen to my 86 prelude. it would die at every light. turns out it was overheating, so maybe its that. i dunno about the black smoke, maybe your carb needs to be cleaned.
Don't fall asleep or we'll mutilate your genitals.......
Old 04-14-2004, 02:00 PM
88 ROCKET 88 ROCKET is offline
Check the smoke out the back... white?... black?... could be a head gasket if white. Head gasket would cause loss of compression and check your coolant level, coolant will leak into the cylinder and vaporize into steam and come out the tail pipe as "white smoke"... Give the car a tune up. start simple, plugs, wires, distributer and rotor. The idle sounds like a vacuum issue or the high speed idle valve isn't working. Sounds like your transmission is slipping real bad as well, if automatic, check the dip stick with the car idling in park, IF LOW, add automatic trans. fluid through the dip stick hole... DON'T OVERFILL IT! sounds like it just needs some TLC. Try the tune up first... I have a 88 lude and It is fantastic but requires TLC every now and then.
Old 04-22-2004, 11:21 AM
How are you coming along on your lude?...
