Cooling Problems
I can't figure out why my camry is overheating when a/c turned off and temperature is normal when a/c is running. Need to figure out ASAP. Any immediate assistance would be greatly appreciated.
Re: Cooling Problems
Possibly, your primary cooling fan is not working and the secondary fan cools the radiator when you turn on the A/C. Secondary fan is normally off.
Once your engine is at normal operating temp, the primary fan should come on and off periodically. If it never comes on, you probably have a bad fan motor or a bad fan thermostat. When the engine is cold, open the radiator cap and make sure your coolant level is up to the top. |
Re: Re: Cooling Problems
Both fans come on w/ a/c on
Does one of the fans come on without the A/C on? That is the question. One fan must come on with the A/C off and the engine hot.
my camry had that problem it was fan relay no 1 went bad.
Bad head Gasket !!!
