Old 04-11-2004, 12:50 PM
Kizer Kizer is offline
Talking Posi for 99 Tahoe?
I recently purchased a 2 door LT Tahoe. This is a great truck. I used to have a 76 K5 with Posi rears. This Tahoe however does not. I know that there is a manual 4x4 locker for the front axel. What can I doo frot the rear axel? Was a posi available for the 99's
Thanks
Old 04-11-2004, 12:51 PM
Re: Posi for 99 Tahoe?
axle duh!
Old 06-01-2004, 08:08 PM
ch9493 ch9493 is offline
99 Posi
Yes they did come with posi from the factory. Any Tahoe with the towing package (Z71) option on the build sheet will have it and 3.73 gears. But this will be the new generation of limited slip. If you jack it up and spin the tires, both tires won't spin like the old style posi units. These new units will only lock up if one tire or another looses 20-30% of its traction. So, it will be difficult to find a set up in the junk yard unless you can run the vin number to see if it has the limited slip. I am not sure if they make a Auburn unit for this year tahoe yet, but you could check.
Good Luck
C
determine posi for 88 caprice youngwit88caprice Caprice 0 04-24-2009 03:58 PM
Wanted: 12 bolt posi for GM A-body jlcljayne Classic GTO's (1964-1974) 2 08-03-2005 11:35 PM
Wanted: 12 bolt posi for GM A-body jlcljayne Cutlass Series 1 05-22-2005 07:37 AM
Wanted: 12 bolt posi for GM A-body jlcljayne Chevelle 0 04-01-2005 12:08 AM
eaton posi for 85' c10 nick6160 C/K 0 03-15-2005 10:38 PM
