Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 04-11-2004, 12:23 PM
drthysggs drthysggs is offline
Question running hot?? help!!!!! 97 dodge intrepid 3.5L
My 1997 dodge intrepid 3.5 L V6 is running hot. I've replaced the thermostat, water pump, fuel injector rails gaskets, plugs, flushed the radiator, checked all vacuum lines, upper and lower intake gaskets. It has plenty of power but after about 3 to 5 miles it runs hot. While idling it stays at the normal temp. It doesn't knock and there isn't water in the oil. Please Help!! MY JOB DEPENDS ON IT!!!
Old 04-11-2004, 02:02 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: running hot?? help!!!!! 97 dodge intrepid 3.5L
Coolant sensors.
Old 04-13-2004, 12:47 AM
Dave1979 Dave1979 is offline
unplug your ect (engine coolant temp sensor) pigtail them together, turn the key on.... does the fan kick on... if they dont it could mean 1 of 2 things bad relay or fan motor..... if they do kick on..... replace sensor...
Old 04-22-2004, 05:45 PM
94DI 94DI is offline
I Have a 94 with a 3.5 and it did that to
I had to bleed the cooling system out
you have to do that at running temp.
Old 05-02-2004, 06:23 PM
5spd 5spd is offline
I think you should take 94DI's advice and bleed the coolant system (while at running temp and vehicle running). The bleeder is located on the top of the engine, in front of the plastic intake and looks like a brake bleeder. Pinch off your overflow and run your heater while bleeding your system. Do this until there is a steady stream. You do not have to open the valve alot.
Old 05-04-2004, 02:18 AM
Al_Bundy's Avatar
Al_Bundy Al_Bundy is offline
radiator cap proper pressure?
Check for if the radiator fins clogged with leaves/debris, and hose off.
Make sure fan kicks in.
3.5L V-7 Compressor Removal and Reinstallation krivasauto Intrigue 2 05-13-2010 09:45 PM
1997 Dodge Intrepid 3.5L what side is bank one? hickerbilly Intrepid 12 01-12-2010 08:09 PM
1994 Intrepid 3.5L running on 2-3 of 6 cylinders tyrael2304 Intrepid 5 06-29-2008 02:39 PM
