Old 04-11-2004, 12:15 PM
ldr1ff ldr1ff is offline
Send a message via Yahoo to ldr1ff
Cooling Problems and Gas Mileage
I have a 1996 Blazer 4.3L W-engine. It has about 95,000 miles on it.
The enginer temp gauge is showing 125-130 degrees while my friends Matco scanner shows that is is actually running 190-195 degrees. Is there a way to check if it is the gauge or the sensor?
It is also showing codes SO131 and SO151. It reads as low oxygen sensor voltage for both. Does anyone know which sensors these would be? Is there a way to test the sensors? We also noticed that the scan tool was always showing the air/fuel mix as lean on both banks. I assume that the computer is dumping fuel into the engine to compensate. I am getting only about 12mpg city. Could this be causing this?
Thanks
Gregg
Old 04-11-2004, 12:55 PM
Jeremy-WI Jeremy-WI is offline
Re: Cooling Problems and Gas Mileage
could be an exhaust leak causing it, a bad PCM ground or grounded O2 sensor signal wires
Old 04-27-2004, 12:39 AM
Rowlin Rowlin is offline
i wouldn't worry about the gauge too much i think there are 2 coolent sensors on the block one for the gauge and one for the comp
there is a way of testing the o2 but it involve a multi meter . i think that year has 4 o2 in it and all of the are 4 wire. what u gotta do is find the ground for the o2 i cannot remember what wire it is and measurethe resistace and compare all off them. 1 o2 being off can fudge alot up
Better gas mileage Stapletonb08 Cavalier 3 03-03-2011 02:02 PM
1984 2wd starting problem and gas mileage problem ponylee F Series 2 11-02-2006 09:23 PM
RPM, Cruise Control and Gas Mileage Problems alero2002V6 Alero 4 12-25-2005 09:21 PM
Gas problem, poor gas mileage BlazerGuy19 S-10 2 08-13-2005 11:37 PM
