Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 04-10-2004, 05:01 PM
spedwezl's Avatar
spedwezl spedwezl is offline
Send a message via AIM to spedwezl
why is my speedometer freaking out?
i have a 92 prelude si 4ws and a couple weeks ago i was drivin down the road when my speedometer just kept swingin back to 0 when i was doin like 40. it doesnt do it all the time but its anoying as hell, if anyone could let me know. thanks
Don't fall asleep or we'll mutilate your genitals.......
Old 04-11-2004, 10:46 PM
Dr_Krisp's Avatar
Dr_Krisp Dr_Krisp is offline
Send a message via AIM to Dr_Krisp
same thing happened to my crappy 90 2.0 Si prelude, does the needle jump when you hit your dashboard, when you shift, or both?
Just because i have a small penis does NOT make me any less of a man.
Old 04-12-2004, 09:49 PM
spedwezl's Avatar
it doesnt do it on either. its only when i drive and hit like 40, sometimes...its pissin me off
Old 04-13-2004, 10:05 AM
ShoofIsLudin ShoofIsLudin is offline
in my 94 for a while my speedometer would work till about 30 then drop to 0. Then it stopped working all together, and then it started working again. Its pretty weird...I asked about it when it happened to me, and i only got a few responses, and nobody could really give me a clear answer...good luck
Old 04-13-2004, 11:39 AM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
Re: why is my speedometer freaking out?
Don't quote me... but you guys should check your variable speed sensor (VSS). It is on your transmission near the firewall side. Unplug it and make sure the prongs are still there. Usually when the speedometer goes crazy something is up with the VSS, whether it's broken, malfunctioning, or missing a prong.
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
Old 04-14-2004, 01:47 PM
88 ROCKET 88 ROCKET is offline
If it is a cable connection... like my 88' lude, it is a two piece cable... replace the cable and check the mating gear in the trans. and the speedo.
Old 09-20-2004, 10:39 AM
dude w/ a lude dude w/ a lude is offline
my 86 does that unless i have the e-break on (cables disconected) i cant figure out y but good luck w/ yers
