Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 04-10-2004, 12:22 PM
arcielee arcielee is offline
85 caprice-power steering bugaboo
The problem with this 85 caprice is that we've lost all power steering, yet there is no leak. No hose leaks, no vaccuum leak. No power. None.
Any ideas? Has this happened to anyone else? What's the fix? p.s. we're broke.
Old 04-11-2004, 06:05 AM
dxrflyboy dxrflyboy is offline
Re: 85 caprice-power steering bugaboo
Is this a steering or brake issue?? The power brakes use vacuum assist, unless you have Hydroboost. The power steering uses a pump driven by the engine via a belt off the crankshaft. Check the belt, the fluid level in the pump, and possible leaks.
Old 04-12-2004, 01:21 PM
Sorry-it's a lack of power to the power steering. It's a friend's car. He says the belt has good tension and the fluid level is good. I've checked for leaks and find none. Maybe it's a bad pump...........any other ideas, anyone?
Old 04-12-2004, 05:23 PM
Another possibility is the spool valve in the steering box. It may be stuck in neutral position, bypassing any power assist. Try disconnecting the return hose and plugging the inlet in back of the pump. Connect a tube to the return hose so you can feed it back into the pump through the filler hole on top. Start the engine. See if you have a strong, steady flow of fluid through the return hose. Have someone assist you by turning the steering wheel. Watch for a change in the return flow. No change indicates a spool valve problem. Weak flow indicates a faulty pump.
Power steering flush Windstar 98 - No place to work serge_saati Windstar 9 11-05-2015 08:02 PM
Problems with Acceleration and now Power Steering dbhynds '01-'05 Civic 5 01-06-2010 07:41 AM
Cutlass Supreme - which power steering fluid serge_saati Cutlass Series 1 12-07-2009 07:15 AM
92 Cutlass Supreme Power Steering Hose Mikey_G Cutlass Series 4 11-23-2009 01:47 PM
2000 PA Power Steering Fluid Check buickultra2000 Park Avenue 2 11-12-2009 10:12 AM
